Forced subtitles doesn't work
bscoub
#1 Post by bscoub » Sun Sep 16, 2012 3:13 pm
This message is a bug report : When trying to make a MKV file from any blu ray disk, if I choose force subtiles, no subtile is exported in the resulted mkv file. I am using makemkv release 1.7.7 on my MacBook Pro.
Thank you for considering this book in the next release of makemkv.
Sincerely.
Romansh
Re: Forced subtitles doesn't work
#2 Post by Romansh » Sun Sep 16, 2012 3:57 pm
Which Blu-ray(s) did you try?
Not all Blu-rays have forced subtitles actually flagged as forced within the subtitle stream (or any forced subtitles, for that matter).
bscoub
#3 Post by bscoub » Sun Sep 16, 2012 4:21 pm
I have try Contact which have forced subtitled build in.
Romansh
#4 Post by Romansh » Sun Sep 16, 2012 6:18 pm
Did you try including all forced and non-forced English streams? Forced subtitles can sometimes be found in "non-forced" streams.
bscoub
#5 Post by bscoub » Sun Sep 16, 2012 8:35 pm
Yes, I have tried selecting all force and non forced subtitles (in French language in my case). In this case, I have all the subtitles of the movie in the resulted mkv file, but I just wanted forced subtitled. I have the same problem with many movies.
