What am I doing wrong
tired82
Post by tired82 »
I have been trying for 3 days now to figure out how to rip dvds to my hard drive, and play them on XBMC. Now after going through some setup guides on XBMC I figured my biggest issue is at the very beginning which is when I rip them. I just tired again looking over another tutorial for Makemkv they all seem to be pretty vague. Here is a screen shot of when I recently tried to rip a dvd.
Do I need to change the minimum title length settings.
Am I clicking the wrong title. I don't know thats why I am here.
screen shot of last Makemkv attempt.
Gadgetman!
Re: What am I doing wrong
Post by Gadgetman! »
No, looks like you ticked all the right boxes.
1. Verify that you can write to the Movies folder on that drive, or set it to write to a folder on your C: and try to save to that.
2. If that didn't give any clues, switch on debugging and try again.
Mac Mini, 2005 with superdrive, 2GB RAM, 80GB SSD, Core2Duo 2.16GHz CPU...
2 x LG USB DVD-drives and 'old spiteful' an IDE-based DVD-reader from a desktop connected to the internals of an old FW-HDD.
Writes Sci-fi:
http://www.planetfurry.com/~anthony/
tired82
Post by tired82 »
Gadgetman! wrote:No, looks like you ticked all the right boxes.
How do I verify that I can write to the movies folder, This is my 4th attempt the first 2 I left everything checked and they were copied to my movies folder just not seamless. The last 2 only do it as a title00, or title 01.
2. If that didn't give any clues, switch on debugging and try again..
Though I will look into that, how do I go about doing that "debugging"
Thanks for your help I will try some of these tips.
tired82
Post by tired82 »
I was able to rip it to my c drive with no problem. I then tried to transfer it to my external hard drive and when I did it told me the file was to large, about 4.5 gb how is it to big when I have 300 gigs of free space. Is there some sort of setting that I might be able to change.
paulster
Post by paulster »
You've probably got your external drive formatted in FAT32, which has a filesize limit of 4GB.
You need to reformat in NTFS or one of the other formats that allows for large files.
tired82
Post by tired82 »
paulster wrote:You've probably got your external drive formatted in FAT32, which has a filesize limit of 4GB.
That is exactly what the problem was, I have done this and everything works great.
Thanks for all your help.
