Talladega Nights Blu-ray
manthrax
#1 Post by manthrax » Thu Sep 13, 2012 3:15 am
Whole series of "The source file '/BDMV/STREAM/00017.m2ts' is corrupt or invalid at offset xxxx" messages. Also, the program hangs for a while - with debug on it just hangs forever (well, OK, I didn't let it run that long). Without debug it exits with a "Failed to save title 0 to file C:/Video/LOGICAL_VOLUME_ID/title00" message. Note that this does not correctly pick up the title of the disc either.
BlackDragon24
Re: Talladega Nights Blu-ray
#2 Post by BlackDragon24 » Fri Sep 14, 2012 2:03 pm
manthrax wrote:Whole series of "The source file '/BDMV/STREAM/00017.m2ts' is corrupt or invalid at offset xxxx" messages. Also, the program hangs for a while - with debug on it just hangs forever (well, OK, I didn't let it run that long). Without debug it exits with a "Failed to save title 0 to file C:/Video/LOGICAL_VOLUME_ID/title00" message. Note that this does not correctly pick up the title of the disc either.
Logfile attached.
Most likely a scratched or poorly pressed disc.
I have backed up this title with no problems.
manthrax
#3 Post by manthrax » Sun Sep 16, 2012 12:14 am
Looks like you are correct - I returned the disc to the store & the new one seems to work fine. Thanks!
