Teen Titans: Trouble in Tokyo
slith
#1 Post by slith » Wed Sep 05, 2012 10:40 am
I am using MakeMKV v1.7.7 32-bit on Windows XP SP3. I believe there is just the one version of Teen Titans: Trouble in Tokyo available on DVD.
When opening the disk it does not detect the main movie. Handbrake and VLC Player handle it fine. They see the main movie as Title 1 with length 1:15:02. MakeMKV says the following when opening the disk:
MakeMKV v1.7.7 win(x86-release) started
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 1 chapters
Title #0 (1:15:02) was skipped due to navigation error
Title #1 has length of 12 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #2 was added (1 cell(s), 0:12:05)
Title #3 has length of 12 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #4/1 has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #4/2 was added (1 cell(s), 0:01:17)
Title #4/3 has length of 29 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Cells 5-end were skipped due to cell commands (structure protection?)
Title #5 was added (4 cell(s), 0:03:34)
Title #6 (0:00:40) was skipped due to navigation error
Title #7 (0:00:33) was skipped due to navigation error
Title #8 (0:01:49) was skipped due to navigation error
Title #9 (0:00:32) was skipped due to navigation error
Cells 2-end were skipped due to cell commands (structure protection?)
Title #10 was added (1 cell(s), 0:01:30)
Title #11 has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/1 has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/2 has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/3 has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/4 has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/5 has length of 4 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/6 has length of 25 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/7 has length of 25 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/8 has length of 25 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/9 has length of 9 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/10 has length of 28 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/11 has length of 28 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/12 has length of 28 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11/13 was added (1 cell(s), 0:00:37)
Title #11/14 has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Re: Teen Titans: Trouble in Tokyo
#2 Post by mike admin » Wed Sep 12, 2012 5:50 am
Please enable debug logging and send IFO files per http://www.makemkv.com/faq/item/8
slith
#3 Post by slith » Wed Oct 17, 2012 10:35 am
Hi, I presume that the debug logging and IFO files that I sent through were received. I've just tried MakeMKV v1.7.8 and this has the same problem that previous versions of MakeMKV have had. ie, I still get this error: "Title #0 (1:15:02) was skipped due to navigation error"
slith
#4 Post by slith » Sat Jan 05, 2013 11:13 am
Have just tried v1.7.10 and the problem still exists.
