**RESOLVED** Problems ripping Blu-Ray Funny People US Region
50CalAL
#1 Post by 50CalAL » Sun Dec 06, 2009 3:26 am
I was unable to rip blu-ray "Funny People" (US Region) with 1.4.8 or 1.4.9.
Here is the MakeMKV_log from \User\MakeMKV_log:
Debug log started at Sun Nov 29 16:57:34 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/klandragon/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
003010:000000:0000 Using direct disc access mode
DISCID=52EB490C6B8D6E9238DCF4047CC81FF4FCEF55C6
003020:000000:0000 Title #00099.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00004
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00005
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00006
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00047
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01052
003020:000000:0000 Title #01056.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #01057.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01058
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01059
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01060
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01061
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01062
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00040
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00041
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00042
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00043
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00044
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00045
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00046
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01105
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01106
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01107
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01108
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01109
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01110
001011:000000:0020 LIBMKV_TRACE: No CC5 in 01111
003313:000000:0000 File 00010.mpls was added as title #0
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00082.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00115.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00106.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00116.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00107.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00117.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00108.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00118.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00109.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00119.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00110.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00120.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00111.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00121.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00112.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00122.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00113.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00123.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00114.m2ts
003313:000000:0000 File 00001.mpls was added as title #1
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00124.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00125.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00126.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00127.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00128.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00129.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00130.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00131.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00132.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00133.m2ts
003313:000000:0000 File 00003.mpls was added as title #2
003313:000000:0000 File 00000.mpls was added as title #3
003313:000000:0000 File 00002.mpls was added as title #4
003313:000000:0000 File 00065.mpls was added as title #5
003313:000000:0000 File 00066.mpls was added as title #6
003313:000000:0000 File 00067.mpls was added as title #7
003313:000000:0000 File 00068.mpls was added as title #8
003313:000000:0000 File 00069.mpls was added as title #9
003313:000000:0000 File 00054.mpls was added as title #10
003020:000000:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00083.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00084.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00086.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003314:000000:0000 Title 00001.mpls is equal to title 00000.mpls and was skipped
003314:000000:0000 Title 00003.mpls is equal to title 00002.mpls and was skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Volumes/50CalAL_BD_RIPS/Movies
001012:000000:0020 FAILURE: Code 2 at Y89?Uipt6*g-w=I?:213135251
SD=ZeNorYGBiAAIuIL5hAGZCQB77h2lLkhkYGKH8DUC+QzoDw38gCPliARbzANIAU60OXg==
001012:000000:0020 FAILURE: Code 4294967276 at @5_r6=!rR4?0;u;":121267270
001012:000000:0020 FAILURE: Code 0 at @5_r6=!rR4?0;u;":213134837
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:29394068
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:121262601
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:29394597
002007:000000:0000 Read error. File="<n/a>" Info=""
001012:000000:0020 FAILURE: Code 0 at )MSesRdk.'R(!BY%]w<E:121262509
001012:000000:0020 FAILURE: Code 0 at [iead6MKH~pEx6+G,Ifo:121262049
001012:000000:0020 FAILURE: Code 0 at )MSesRdk.'R(!BY%]w<E:121262164
001012:000000:0020 FAILURE: Code 151519 at )MSesRdk.'R(!BY%]w<E:213129639
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 1 to file /Volumes/50CalAL_BD_RIPS/Movies/title01.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Re: Problems ripping Blu-Ray Funny People US Region
#2 Post by mike admin » Sun Dec 06, 2009 8:37 am
Your drive fails to read the data with an error that makes no sense to me
CANNOT READ MEDIUM - INCOMPATIBLE FORMAT
Is this the only disc that fails? Is there anything special about this particular disc? Do you have any program installed that is related to blu-ray drive in any way?
Can you please try to copy all files to harddrive and see if you get any errors?
50CalAL
#3 Post by 50CalAL » Sun Dec 06, 2009 9:00 am
No, Bangkok Dangerous and Defiance also failed with similar error but I don't have those discs any longer and inadvertently deleted the log files
Not that I know of, the format/construction of the disc looks similar to Land of the Lost but that blu-ray was ripped w/no issues
I also have a program called Pavtube Blu-Ray Ripper for Mac but it's not specific to that drive. I am using a LG WH08LS20 Blu-Ray burner and all the software that came with it is for Windows so it isn't installed as I'm using this burner on a Mac.
I have not tried this yet but will do so 1st chance I get and post the results here
50CalAL
#4 Post by 50CalAL » Tue Dec 08, 2009 8:21 am
So I was able to copy all the files from the blu-ray funny people, after a couple of attempts.
When I try to rip the files I get this error:
Debug log started at Tue Dec 8 08:09:02 2009 , written by MakeMKV v1.4.9 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/50CalAL/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at fSxrS|A(s^T&@zxxNi2'W7V$14E:121264878
003006:000000:0000 Opening files on harddrive at /Users/50CalAL/Desktop/Funny People/
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:121263015
001012:000000:0020 FAILURE: Code 0 at !Uud`<Q?DpwZ?V*RF*v:213132652
005010:000000:0000 Failed to open disc
Any ideas Mike?
#5 Post by mike admin » Sat Dec 12, 2009 9:49 am
you can't just copy files and open the copy, I've asked you to copy in order to see if it is any problem with the disc or drive. you mentioned "attempts", what kind of error was happening when you copied files?
50CalAL
#6 Post by 50CalAL » Tue Dec 15, 2009 4:23 am
I originally tried copying all the files from the blu-ray to my HD at once and got an error saying some of the files could not be copied. So I copied the files a small group at a time and found one of the .m2ts files couldn't be copied and got an error saying the file couldn't be copied and some of the file can't be read or written.
After a couple of attempts though I was able to copy all the files to my HD.
#7 Post by mike admin » Wed Dec 16, 2009 9:43 am
50CalAL wrote: So I copied the files a small group at a time and found one of the .m2ts files couldn't be copied and got an error saying the file couldn't be copied and some of the file can't be read or written.
This is precisely the error that MakeMKV encounters and then fails. It looks very likely that it is a problem with a drive.
50CalAL
#8 Post by 50CalAL » Sun Dec 20, 2009 5:51 am
After copying the files to my HD, I figured for shits and giggles I'd try one last time to rip the movie and low and behold it worked this time :D
Thanks for your help Mike.
