I use MakeMKV extensively. I like the program very much.
If I were to pay the $50.00 charge, would the current version I am using, or any future version, still be time-limited?
Would I be able to update the program at any time? Would I need to re-enter the key into that future version or would it be automatically incorporated?
Would the $50.00 charge be applicable to more than one computer? I currently use MakeMKV on two computers.
Thanks for a great program.
If I Pay $50.00, Is My Current Version Still Time-Limited?
lhb1142
Romansh
Re: If I Pay $50.00, Is My Current Version Still Time-Limite
I don't believe so.lhb1142 wrote:If I were to pay the $50.00 charge, would the current version I am using, or any future version, still be time-limited?
As I understand it, licenses purchased during beta are "lifetime" licences.lhb1142 wrote:Would I be able to update the program at any time? Would I need to re-enter the key into that future version or would it be automatically incorporated?
Maybe, but not at the same time.lhb1142 wrote:Would the $50.00 charge be applicable to more than one computer? I currently use MakeMKV on two computers.
NutFlush920
When you pay for the license MakeMKV is not time limited and will continue to work even if the beta key expires. As I understand it, it includes lifetime updates. You can install using your same key on multiple computers however, per the license agreement you can only use it one one computer at a time meaning you can't be running it on computer A on Fast and Furious and computer B on Jurassic Park at the same exact moment.
In my opinion, it is easily worth the $50 fee.
lhb1142
To Romansh and NutFlush920:NutFlush920 wrote:When you pay for the license MakeMKV is not time limited and will continue to work even if the beta key expires. As I understand it, it includes lifetime updates. You can install using your same key on multiple computers however, per the license agreement you can only use it one one computer at a time meaning you can't be running it on computer A on Fast and Furious and computer B on Jurassic Park at the same exact moment.
Thank you very much for this information. I just purchased and installed the program key. It definitely is worth the $50.00.
Thanks again.
Lawrence
NutFlush920
You're welcome and enjoy
