MakeMKV v1.7.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BH14NS40 1.00' at offset '24940247040'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00035.m2ts' at offset '1111425024'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00037.m2ts' at offset '260745216'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00037.m2ts' at offset '1634304'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '24940247040'
File 00000.mpls was added as title #0
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00037.m2ts' at offset '0'
Title #00036.mpls was skipped
Title #00046.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00047.mpls was added as title #1
File 00048.mpls was added as title #2
Title #00003.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00034.m2ts was added as title #3
File 00035.m2ts was added as title #4
Title #00036.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00038.m2ts' at offset '0'
Title #00038.m2ts was skipped
Title #00041.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00046.m2ts was added as title #5
Saving 1 titles into directory F:/MKV Files
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00044.m2ts' at offset '8045789184'
Failed to save title 2 to file F:/MKV Files/title02.mkv
0 titles saved, 1 failed
Basic Instinct
Re: Basic Instinct
Looks like a dirty or damaged disc.
Swap it for a new one.
Re: Basic Instinct
So, that's what ALL that tells me?!?! Is it possible it could be ANYTHING else?
Re: Basic Instinct
Your drive is telling MakeMKV it can't read the disc.
Could be your drive is dying.
Re: Basic Instinct
It better not be dying!!! It's less 3 months old!!! It works well with 98% of all the other Blu Rays I've run. Just "Basic Instinct" and "Thor" gave me this issue. Both discs looks clean, very clean actually. I got another copy of "Thor" and will try again tonight.
Re: Basic Instinct
A second copy of the movie "Thor" worked flawlessly. So, apparently it was the disc...PHEW!!!
Thanks for your help!
