MKV allowing an M2TS to pass Decoding
jatarala
Post by jatarala »
I just used MakeMKV to decrypt Life in Blu-Ray. Most of the episodes decrypted just fine. However, when I got to one episode (out of 10!) the last title (or chapter) did not decrypt and was left as an M2TS file:
File 00109.mpls was added as title #0
File 00110.mpls was added as title #1
File 00111.mpls was added as title #2
File 00116.mpls was added as title #3
File 00026.mpls was added as title #4
File 00028.mpls was added as title #5
Title 00112.mpls is equal to title 00109.mpls and was skipped
Title 00113.mpls is equal to title 00110.mpls and was skipped
Title 00114.mpls is equal to title 00111.mpls and was skipped
Title 00115.mpls is equal to title 00109.mpls and was skipped
Title #00000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #6
Title #00054.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I was wondering how I can get around this?!
Re: MKV allowing an M2TS to pass Decoding
Post by mike admin »
Please submit MPLC/CLPI files with a link to this post per http://www.makemkv.com/faq/item/8
