Source file corrupt error
portfolis
Re: Source file corrupt error
#16 Post by portfolis » Sun Sep 02, 2012 8:32 pm
Hi! Thanks for response.
I have only a copy of DVD ("VIDEO_TS" folder), and I haven't the original DVD. The copy contains four episodes of the serial. And the third can't be copied (can't be saved to .mkv), but all players can play it from that folder. The rest of episodes saved to .mkv without problems. I tried to work with ISO and tried directly with "VIDEO_TS"... the result was the same.
Here is the log:
MakeMKV v1.7.7 win(x86-release) started
Opening files on harddrive at U:/Склад/Season 3/BUFFYS3D5/VIDEO_TS
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Title #0 was added (22 cell(s), 0:44:00)
Title #1 was added (23 cell(s), 0:44:19)
Title #2 was added (22 cell(s), 0:43:56)
Title #3 was added (21 cell(s), 0:42:39)
Title #4 was added (1 cell(s), 0:05:58)
Title #5 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 4 titles into directory V:/Test
The source file 'U:/Склад/Season 3/BUFFYS3D5/VIDEO_TS/VTS_03_5.VOB' is corrupt or invalid at offset 991862784, attempting to work around
Failed to save title 2 to file V:/Test/title02.mkv
3 titles saved, 1 failed
#17 Post by mike admin » Tue Sep 04, 2012 6:50 am
Your file is huge. Please do the test dump only for the title that fails per instructions at http://www.makemkv.com/onlinehelp/testdump.html .
#18 Post by mike admin » Mon Sep 10, 2012 1:40 am
Also please note that discussion about copying content that you have no rights for is not allowed on this forum.
Locked
