Is MakeMKV compatible with BDAV?
powdrsnow
#1 Post by powdrsnow » Tue Sep 04, 2012 6:11 am
I have some blu-ray discs which were burned using a Sony Blu-ray recorder from Japan. As I understand it, Blu-ray recorders use this format called BDAV. It seems that MakeMKV has a hard time reading these discs. The Blu-ray drive works fine. I am thinking MakeMKV just supports BDMV which is the commercial blu-ray discs.
Does anyone know anything about this? If anyone knows about this, i would appreciate some info.
If MakeMKV doesn't support BDAV, how can we make this happen? Thanks.
Re: Is MakeMKV compatible with BDAV?
#2 Post by mike admin » Tue Sep 04, 2012 7:08 am
powdrsnow wrote:If MakeMKV doesn't support BDAV, how can we make this happen? Thanks.
It doesn't now, the feature is planned for a long time, but is yet missing.
solrac42
#3 Post by solrac42 » Wed Dec 12, 2012 5:11 pm
powdrsnow wrote:I have some blu-ray discs which were burned using a Sony Blu-ray recorder from Japan. As I understand it, Blu-ray recorders use this format called BDAV. It seems that MakeMKV has a hard time reading these discs. The Blu-ray drive works fine. I am thinking MakeMKV just supports BDMV which is the commercial blu-ray discs.
I am a brand new member to this forum, but a veteran at DVDFab forum, you will be pleased to know that DVDFab can process BDAV discs created on my Panasonic DMR BW780 EB, so it should work for your Sony, but at present it is bugged and cannot finish the process, but it should be fixed very soon, I have a work around for this, the point I am trying to make is that it can be done, so MakeMKV should have this feature.
Still Above Ground ...
