Hiya,
Has anyone successfully done this title? It bombs out even before getting to choose what I want ripped.
Me, Myself and Irene R1 DVD
ldoodle
Re: Me, Myself and Irene R1 DVD
Same thing happens with Spiderman 1 R1 DVD and Superman II R1 DVD.
All 'a fatal error has orccured. The program will now exit'
ldoodle
OK Spider-Man and Superman II seemed to have fixed themselves, but still no luck with Me, Myself and Irene.
Any ideas?
Any ideas?
ldoodle
Still no luck with this.
Even copying the files from the DVD to local disk and opening them in MakeMKV produces the same error:
Debug log started at Sun Dec 27 11:13:43 2009 , written by MakeMKV v1.4.9 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Username/MakeMKV_log.txt
003006:000000:0000 Opening files on harddrive at C:/Users/Username/Movies/Me, Myself & Irene/
Any ideas, please?
Any ideas, please?
ldoodle
This is proving to be a somewhat stupid DVD. 1.4.10 doesn't fix the problem i'm having, but...
- I can rip successfully using DVDFab, but the MKV is only 1.2GB so something's not right in the settings
- If I have AnyDVD running, I can successfully copy the VIDEO_TS folder to my local hard drive, so it's not the disc at fault
- If I add the resulting local copy of the IFO file into MakeMKV, I get the same problem as when doing it straight from disc
The fact I can rip using DVDFab and copy the files from the disc must mean it's a problem with MakeMKV.
Can DVDFab do what MakeMKV can do, i.e. rip as is with the video and main audio track? I thought I had configured it this way but 1.2GB is way to small!
Any ideas, Mike?
Any ideas, Mike?
