Homeland Season 1
Homeland Season 1
MakeMKV v1.7.7 win(x64-release) started
Loaded 71 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\ArieS/.MakeMKV/dump_Homeland__Season_1_Disc_1_62A622B97AEA9376.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
I tried to send the files via email but it looks like the attachment was too big and I couldn't upload it...
What can I do?
What can I do?
Re: Homeland Season 1
I'm getting the same thing for the homeland discs.
Having an issue with episode 3 (disc 1/title 02) of the blu ray. Just trying disc 2 and 3 now.
'The source file '/BDMV/STREAM/00802.m2ts' is corrupt or invalid at offset 4140570624, attempting to work around'
(and other offsets) .. then it finally fails.
Is this the same issue? The other episodes on the disc are fine.
I'm using the latest AnyDVD HD 7.0.7.2 and MakeMKV 1.7.7. Both are registered.
Regards,
Randy
Regards,
Randy
I get the same error on 00802.m2ts even outside of MakeMKV, so it's either an issue with the disc or with AnyDVDHD (I'm using 7.0.8.0).
Well after googling around a bit it seems like lots of people are having this problem.
Has anyone watched the episode on a blu-ray player all the way through to the end?
I'll try that later or tomorrow. The other discs were fine, btw. It's just this one episode. Luckily I have that episode TiVo'd, so I converted that one episode to MKV for now. Being that I own the discs, I'm assuming that's OK legally.BlackDragon24 wrote:Well after googling around a bit it seems like lots of people are having this problem.
Randy
Does anyone know how to upload a dump file? I have problems as well and have a 27mb dump file I can send.
Use a service like sendspace.com
Same problem with disc 2
trying to send dump, but too big for email. Will try another methd
Thank you for the sendspace suggestion. I uploaded the dumpfile for season 1, disc 1 to svq@makemkv.com
http://www.sendspace.com/file/yr7btd
- Contact:
SVQ updated.
All Fixed - All discs ripped correctly
