Homeland Season 1
ArieS
Homeland Season 1
Post by ArieS »
MakeMKV v1.7.7 win(x64-release) started
Loaded 71 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users\ArieS/.MakeMKV/dump_Homeland__Season_1_Disc_1_62A622B97AEA9376.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
I tried to send the files via email but it looks like the attachment was too big and I couldn't upload it...
What can I do?
cybercmw
Re: Homeland Season 1
Post by cybercmw »
I'm getting the same thing for the homeland discs.
repstein
Post by repstein »
Having an issue with episode 3 (disc 1/title 02) of the blu ray. Just trying disc 2 and 3 now.
'The source file '/BDMV/STREAM/00802.m2ts' is corrupt or invalid at offset 4140570624, attempting to work around'
(and other offsets) .. then it finally fails.
Is this the same issue? The other episodes on the disc are fine.
I'm using the latest AnyDVD HD 7.0.7.2 and MakeMKV 1.7.7. Both are registered.
Regards,
Randy
romwarrior
Post by romwarrior »
I get the same error on 00802.m2ts even outside of MakeMKV, so it's either an issue with the disc or with AnyDVDHD (I'm using 7.0.8.0).
BlackDragon24
Post by BlackDragon24 »
Well after googling around a bit it seems like lots of people are having this problem.
Has anyone watched the episode on a blu-ray player all the way through to the end?
repstein
Post by repstein »
BlackDragon24 wrote:Well after googling around a bit it seems like lots of people are having this problem.
I'll try that later or tomorrow. The other discs were fine, btw. It's just this one episode. Luckily I have that episode TiVo'd, so I converted that one episode to MKV for now. Being that I own the discs, I'm assuming that's OK legally.
Randy
testmetest
Post by testmetest »
Does anyone know how to upload a dump file? I have problems as well and have a 27mb dump file I can send.
crowfax
Post by crowfax »
Use a service like sendspace.com
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
thelangs
Post by thelangs »
Same problem with disc 2
trying to send dump, but too big for email. Will try another methd
thelangs
Post by thelangs »
Dump sent via sendspace
http://www.sendspace.com/file/6ogiyr
testmetest
Thank you for the sendspace suggestion. I uploaded the dumpfile for season 1, disc 1 to svq@makemkv.com
http://www.sendspace.com/file/yr7btd
Post by mike admin »
SVQ updated.
thelangs
Post by thelangs »
All Fixed - All discs ripped correctly
