Merging Lord of the Rings Extended Edition Trilogy Set
rpmccly
Post by rpmccly » Tue May 01, 2012 2:16 am
For some reason the Lord of the Rings Extended edition Trilogy set has each movie on 2 seperate discs, so there are 6 total blurays. I would like to merge them but I'm worried about the audio syncing properly and the loss of any quality if I just use any MKV merge program. Has anyone merged these movies or whats the highest quality merge program?
tholau
Re: Merging Lord of the Rings Extended Edition Trilogy Set
Post by tholau » Tue May 01, 2012 3:52 am
Well, I'v done it using MakeMKV to extract the BDs and MKVToolnix (http://www.bunkus.org/videotools/mkvtoo ... loads.html) to crop.
I've cut the end titles of Part I and II, the opening credits from Part II and III with MKVToolnix.
Last step I've merged the parts again with MKVToolnix.
I took untouched video and audio, in audio all the english and german audio tracks are conserved...
Complete name : Herr der Ringe.mkv (I'm german hence The Lord of the rings)
Format : Matroska
Format version : Version 2
File size : 189 GiB
Duration : 10h 55min
Overall bit rate mode : variabel
Overall bit rate : 41,2 Mbps
Encoded date : UTC 2011-11-19 07:25:00
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Ja
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : variabel
Bit rate : 33,6 Mbps
Width : 1 920 Pixel
Height : 1 080 Pixel
Display aspect ratio : 16:9
Frame rate : 23,976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : progressiv
Bits/(Pixel*Frame) : 0.676
Stream size : 154 GiB (81%)
Language : Deutsch
Default : Ja
Forced : Nein
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Bit rate : 1 510 Kbps
Channel(s) : 7 Kan?le / 6 Kan?le
Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48,0 KHz
Bit depth : 24 bits
Compression mode : / Lossy
Stream size : 6,91 GiB (4%)
Title : Lossless
Language : Englisch
Default : Nein
Forced : Nein
Audio #2
Format : DTS
Format profile : ES
Codec ID : A_DTS
Bit rate mode : konstant
Bit depth : 24 bits
Title : 3/2+1
Language : Englisch
Default : Nein
Forced : Nein
Audio #3
Format : DTS
Codec ID : A_DTS
Bit depth : 16 bits
Title : Lossless
Language : Deutsch
Default : Nein
Forced : Nein
Audio #4
Format : DTS
Format profile : ES
Codec ID : A_DTS
Bit depth : 16 bits
Title : 3/2+1
Language : Deutsch
Default : Ja
Forced : Nein
Audio #5
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate : 192 Kbps
Channel(s) : 2 Kan?le
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 900 MiB (0%)
Title : 2/0
Language : Englisch
Default : Nein
Forced : Nein
Audio #6
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Englisch
Default : Nein
Forced : Nein
Audio #7
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Englisch
Default : Nein
Forced : Nein
Audio #8
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 Kbps
Bit depth : 16 bits
Title : 2/0
Language : Englisch
Default : Nein
Forced : Nein
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Englisch
Default : Nein
Forced : Nein
Text #2
Format : PGS
Muxing mode : zlib
Language : Deutsch
Default : Nein
Forced : Nein
Text #3
Format : PGS
Muxing mode : zlib
Language : Englisch
Default : Nein
Forced : Nein
Text #4
Format : PGS
Muxing mode : zlib
Language : Englisch
Default : Nein
Forced : Nein
Text #5
Format : PGS
Muxing mode : zlib
Language : Englisch
Default : Nein
Forced : Nein
Text #6
Format : PGS
Muxing mode : zlib
Language : Englisch
Default : Nein
Forced : Nein
Text #7
Format : PGS
Muxing mode : zlib
Language : Englisch
Default : Nein
Forced : Nein
Text #8
Format : PGS
Muxing mode : zlib
Language : Deutsch
Default : Nein
Forced : Nein
Chapters removed - irrelevant because cropping changed some chapters
tholau 8)
Chetwood
Post by Chetwood » Tue May 01, 2012 6:24 am
In case you're ripping the German version too, check out these proper chapter titles.
bw001
Post by bw001 » Tue May 08, 2012 12:15 am
Here are the steps that I used:
1. Create both mkvs using whatever programs you prefer.
2. Open FOTR part 1 in mkvmerge.
3. Set the output filename to what you want.
4. Note the number of chapters (27).
5. On the global tab, check Enable splitting... ...after this duration. Place 6338s in the box.
6. Start muxing.
7. When complete, close mkvmerge and open FOTR part 2 in mkvmerge. I tend to close it between uses so I don't miss a setting I needed to clear from the last step.
8. Set the output filename to what you want.
9. On the global tabe, check Enable splitting... ...after this duration. Place 00:00:00.500 in the box.
10. In the max. number of files box place 2. This is important as without it you will end up with a lot of files 1/2 a second long.
11. Start muxing.
12. When complete close mkvmerge and open it again.
13. Go to the Chapter Editor tab and drag the FOTR part 2 mkv into the chapters box.
14. Select each chapter in order, changing the name to the next number after the number of chapters in FOTR part 1. Chapter 1 becomes Chapter 28, Chapter 2 becomes Chapter 29, etc.
15. Once finished, on the menu click Chapter Editor > Save.
16. Close mkvmerge and open FOTR part 1 in mkvmerge.
17. Click append and add FOTR part 2.
18. Set the output filename to what you want.
19. Start muxing.
Here are the trim settings for each LOTR EE Blu-rays Part 1 discs:
FOTR EE Part 1 end = 6338 seconds
TTT EE Part 1 end = 6396 seconds
ROTK EE Part 1 end = 7656 seconds
I haven't tried it, but you should be able to get chapter names from http://www.chapterdb.org
mskovgaard
Post by mskovgaard » Fri Aug 31, 2012 9:30 am
Have you had problems merging/appending ROTK to one MKV? I get a warning "The codec's private data does not match". I haven't split the files or modified them in any way. I just use "Append".
Thanks in advance
Morten
Limey
Post by Limey » Wed Oct 17, 2012 5:51 pm
bw001 wrote:Here are the steps that I used:
6. Start muxing.
11. Start muxing.
19. Start muxing.
I tried to follow the above process. Steps 1-6 work fine but I get an error message on Step 11 stating that "The format of the split timecode/duration is invalid." Any ideas? I put the "00.00.00.500" code in the "...after this duration" box, which is how I read the instructions.
Also, FWIW, I tried skipping 7-11 and dragging Pt 2 into the Chapters box. This doesn't work either - it won't accept the file this way.
Any help would be greatly appreciated.
robpdotcom
Post by robpdotcom » Wed Oct 17, 2012 10:20 pm
Limey wrote:I put the "00.00.00.500 " code in the "...after this duration" box, which is how I read the instructions.
Read them again. :mrgreen:
It should be: 00:00:00.500 not 00.00.00.500.
Use colons to separate hours, minutes, and seconds.
Also, for large files it can take a long time for mmg to read the chapters (step 13). It's faster to extract them with mkvextract first.
reddskinnfan
Post by reddskinnfan » Sat Nov 03, 2012 2:39 pm
6. Start muxing.
11. Start muxing.
19. Start muxing.
Personally, the 1st disc trim times seem right on, but the 2nd disc for each movie could be much better. I have found these to work best, without any black space between scenes:
FotR disc 2: ...after 2 seconds
TT disc 2: ...after 1 second
RotK disc 2: ...after 1 second
Just my thoughts. I also used VLC Media Player to find the times, by double-clicking the timestamp and telling it where to start. Takes some testing, but you can find the area where the movie actually has picture and sound starts.
reddskinnfan
Post by reddskinnfan » Sat Nov 03, 2012 6:11 pm
Also, I found the cut off time for the TT to be 6394 on my disc, 6396 left two seconds of black screen.
reddskinnfan
Post by reddskinnfan » Sat Nov 03, 2012 6:56 pm
Also, I found the RotK first disc should be cut to 7655, instead of 7656.
Of course, your mileage may vary.
macseven77
Post by macseven77 » Wed Dec 05, 2012 2:15 am
How do you handle adding subtitles in? I haven't tried to combine them, but to add the subtitles I used makemkv to rip the files from the disc and then used mkvtools, BDSup2Sub, Mkvtoolinx and then used handbrake. Can I do all of this and then follow the steps above to combine and then rip again with handbrake?
KiltedShane
Post by KiltedShane » Thu Jan 03, 2013 7:42 pm
mskovgaard wrote:Hi,
Thanks in advance
Morten
I am seeing the same thing. TLOR: FOTR merged without any problems but TTT and TROTK give me "... The codec's private data does not match (lengths: 68 and 191). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file."
I ripped them from new blu-rays with MakeMKV. Looking at the codec information in VLC player they are exactly the same.
KiltedShane
Post by KiltedShane » Thu Jan 03, 2013 10:27 pm
I tried it again after following bw001's most excellent guide and still get
Warning: The track number 0 from the file 'D:\Video\BLAH-BLAH002".mkv' can probably not be appended correctly to the track number 0 from the file 'D:\Video\BLAH-BLAH001.mkv': The codec's private data does not match (lengths: 68 and 191). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file.
lfoust
Post by lfoust » Thu Jan 17, 2013 7:29 am
This is a great guide and worked perfectly for me. Thanks!
Sky Walker 37
Post by Sky Walker 37 » Sun Apr 07, 2013 7:43 am
6. Start muxing.
11. Start muxing.
19. Start muxing.
I tried all the steps but in the last step when trying muxing the two files it gives me following error:
" Appending a track from a file to another track from the same file is not allowed. This is the case for tracks number 14 & 15"
I reviewed everything but there are two different files with different chapter info.
Please advise.
Thanks.
