1.7.7 seems not working
sakajah2
Post by sakajah2 » Thu Aug 30, 2012 1:56 pm
Hi there,
I'm new to MakeMKV. When I tried with BD-ROM, it worked just fine.
However, with BD-R didn't work. BD-RE either. The version is 1.7.7.
More analytically, the makemkvcon fails with segmentation fault,
and makemkv says type is data.
I'm using Mitsubishi Blu-ray recorder and LG BD-RE BT10N under Ubuntu 12.04.
Any ideas?
nickblack
Re: 1.7.7 seems not working
Post by nickblack » Fri Aug 31, 2012 9:22 pm
sakajah2 wrote:Hi there,
Any ideas?
1.7.7 is working just fine for me. iHBS112 over SATA, 3.5.3 kerenl.
Including strace output or a decoded coredump would be most helpful.
sakajah2
Post by sakajah2 » Sat Sep 01, 2012 2:23 am
Any ideas?
I appreciate for your kindness. I didn't get core file by executing makemkv.
I attach strace log for both makemkv and makemkvcon, and a core file by makemkvcon.
Thanks in advance.
sakajah2
Post by sakajah2 » Sat Sep 01, 2012 2:47 am
It seems I missed the files. I get a warning message "The extension tracelog is not allowed."
How can I send you the files.
sakajah2
Post by sakajah2 » Sun Sep 02, 2012 12:53 am
I stored the files to:
http://file-post.net/ja/fs5/data/134654 ... F5N2jc7Bwf
Best regards.
sakajah2
Post by sakajah2 » Mon Sep 10, 2012 11:58 am
sakajah2 wrote:I stored the files to:
Best regards.
I re-uploaded the files again on following link.
http://file-post.net/ja/fs5/data/134727 ... fpXD8YBvGB
Thanks in advance.
sakajah2
Post by sakajah2 » Mon Sep 10, 2012 1:58 pm
I also tried on win7. I have same error.
Have anyone succeeded to play BD-R which was recorded
by using any Mitsubishi recorders?
