Sons of Anarchy Season 4
T3slider
Post by T3slider »
Sons of Anarchy season 4 on Blu-ray will not load using MakeMKV 1.7.7 on 64-bit Linux. I'm assuming it needs its own SVQ for now. Here's a sample log from disc 3:
Debug log started at Thu Aug 30 02:23:22 2012 , written by MakeMKV v1.7.7 linux(x64-release)
Using 131328KB for read cache.
001005:0000 MakeMKV v1.7.7 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/userdel/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQUEAQEBAUJNQTI1NDYgAQoADEZEQwA=
DCE=rhNSlap3mi+dJLr/Csjk/TE5CIPyVeTHIdoKf2l31P2+MyS2kxVOQ3yfBajQ7JBNgS6PHK/qs8M6Ng6b12VTJ6PfymdxSvFiOpVVtwb4bNVCkAa1tioiYZZUQy8YXXuqfEdpq45Vw9pm86Tm3nrSz8tneWTl8mNATw==
003317:0000 Loaded 71 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
001003:0020 DEBUG: Code 0 at ?CSyB\3?P?%Q2-0z:29400531
001003:0020 DEBUG: Code 0 at ?CSyB\3?P?%Q2-0z:29398254
001003:0020 DEBUG: Code 0 at ?CSyB\3?P?%Q2-0z:213139690
003325:0000 Failed to process BD+ code using generic SVQ from builtin/00000.svq
001003:0020 DEBUG: Code 0 at f$E_l4LOfu!dO7MeX#:121265752
003332:0000 Saved BD+ dump file as /home/userdel/.MakeMKV/dump_Sons_of_Anarchy__Season_4_Disc_3_EFBA20C926EA3341.tgz
003321:0000 Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
001003:0020 DEBUG: Code 0 at |r09XNmWTptFl)" :29396897
Application exited at Thu Aug 30 02:24:24 2012
Dump files for each disc:
https://docs.google.com/open?id=0BxkcdF ... lpId2VydUU
https://docs.google.com/open?id=0BxkcdF ... U04LUFhT2M
https://docs.google.com/open?id=0BxkcdF ... WF1eGMxYVU
[edit]The forums seem to have killed the links...
Disc 1
Disc 2
Disc 3
[/edit]
Re: Sons of Anarchy Season 4
Post by mike admin »
SVQ updated.
