The Hunger Games BD, which chapters to choose
Re: The Hunger Games BD, which chapters to choose
Post by SamuriHL » Sun Aug 26, 2012 7:34 pm
Ooook, I'm done in this thread. Have fun with this disc and being rude to each other.
DJRumpy
Post by DJRumpy » Sun Aug 26, 2012 8:29 pm
Hell half of the image sharing sites require you to register these days :\
In any case, this is what I see when I load it up:
http://imm.io/C7bx
This is from the two disk set (special features on the second disk). 2-Disk Blu-Ray + Digital Copy.
Not sure if there is a code (sku) somewhere that I can post to indicate which one it is.
Edit: The Fry's receipt says it's UPC: 031398155546
DJRumpy
Post by DJRumpy » Sun Aug 26, 2012 8:33 pm
This the the full list of everything it skipped:
Title #00003.mpls has length of 72 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
File 00004.mpls was added as title #0
File 00007.mpls was added as title #1
File 00010.mpls was added as title #2
File 00044.mpls was added as title #3
File 00076.mpls was added as title #4
Title 00093.mpls is equal to title 00010.mpls and was skipped
Title 00108.mpls is equal to title 00076.mpls and was skipped
Title 00109.mpls is equal to title 00004.mpls and was skipped
Title 00110.mpls is equal to title 00044.mpls and was skipped
Title 00145.mpls is equal to title 00007.mpls and was skipped
File 00234.mpls was added as title #5
Title 00247.mpls is equal to title 00010.mpls and was skipped
Title 00257.mpls is equal to title 00007.mpls and was skipped
Title 00262.mpls is equal to title 00007.mpls and was skipped
Title 00277.mpls is equal to title 00234.mpls and was skipped
Title 00289.mpls is equal to title 00004.mpls and was skipped
Title 00292.mpls is equal to title 00234.mpls and was skipped
File 00321.mpls(2) was added as title #6
Title 00326.mpls is equal to title 00044.mpls and was skipped
Title 00336.mpls is equal to title 00010.mpls and was skipped
Title 00347.mpls is equal to title 00004.mpls and was skipped
File 00352.mpls was added as title #7
Title 00364.mpls is equal to title 00044.mpls and was skipped
Title 00376.mpls is equal to title 00004.mpls and was skipped
Title 00381.mpls is equal to title 00010.mpls and was skipped
Title 00399.mpls is equal to title 00007.mpls and was skipped
Title 00447.mpls is equal to title 00076.mpls and was skipped
Title #00451.mpls has length of 227 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title 00462.mpls is equal to title 00076.mpls and was skipped
Title 00523.mpls is equal to title 00234.mpls and was skipped
File 00526.mpls was added as title #8
Title 00534.mpls is equal to title 00234.mpls and was skipped
Title 00540.mpls is equal to title 00007.mpls and was skipped
Title 00565.mpls is equal to title 00076.mpls and was skipped
Title 00572.mpls is equal to title 00352.mpls and was skipped
Title 00590.mpls is equal to title 00010.mpls and was skipped
Title 00597.mpls is equal to title 00004.mpls and was skipped
Title 00621.mpls is equal to title 00007.mpls and was skipped
Title 00645.mpls is equal to title 00044.mpls and was skipped
Title 00653.mpls is equal to title 00004.mpls and was skipped
Title 00665.mpls is equal to title 00076.mpls and was skipped
Title 00685.mpls is equal to title 00234.mpls and was skipped
Title 00686.mpls is equal to title 00234.mpls and was skipped
Title #00700.mpls has length of 227 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title 00703.mpls is equal to title 00007.mpls and was skipped
Title 00716.mpls is equal to title 00007.mpls and was skipped
Title 00723.mpls is equal to title 00352.mpls and was skipped
Title 00726.mpls is equal to title 00352.mpls and was skipped
Title 00735.mpls is equal to title 00234.mpls and was skipped
Title 00760.mpls is equal to title 00044.mpls and was skipped
Title 00778.mpls is equal to title 00352.mpls and was skipped
Title 00785.mpls is equal to title 00234.mpls and was skipped
Title 00808.mpls is equal to title 00044.mpls and was skipped
Title 00810.mpls is equal to title 00352.mpls and was skipped
Title 00817.mpls is equal to title 00010.mpls and was skipped
Title 00821.mpls is equal to title 00044.mpls and was skipped
Title 00832.mpls is equal to title 00076.mpls and was skipped
Title 00843.mpls is equal to title 00076.mpls and was skipped
Title 00876.mpls is equal to title 00076.mpls and was skipped
Title 00894.mpls is equal to title 00044.mpls and was skipped
Title 00951.mpls is equal to title 00044.mpls and was skipped
Title 00964.mpls is equal to title 00004.mpls and was skipped
Title 00971.mpls is equal to title 00076.mpls and was skipped
Title 00973.mpls is equal to title 00007.mpls and was skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00020.m2ts has length of 57 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00021.m2ts has length of 77 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00023.m2ts has length of 14 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00027.m2ts has length of 22 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00029.m2ts has length of 65 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00032.m2ts has length of 22 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00079.m2ts has length of 16 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00081.m2ts has length of 18 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00114.m2ts has length of 37 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00115.m2ts has length of 34 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00449.m2ts has length of 84 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00450.m2ts has length of 80 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00451.m2ts has length of 147 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00452.m2ts has length of 124 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00453.m2ts has length of 80 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #00702.m2ts has length of 31 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
Title #04321.m2ts has length of 60 seconds which is less than minimum title length of 1500 seconds and was therefore skipped
joe42
Post by joe42 » Sun Aug 26, 2012 9:03 pm
Interesting. Note that yours skipped 53 titles because they were "equal to" other titles. Mine only skipped one of those. I'm not sure why the difference. I am running v1.7.7 on Windows. You appear to be running it under MacOS, but I don't know what version of MakeMKV that is.
DJRumpy
Post by DJRumpy » Sun Aug 26, 2012 9:14 pm
Mine is reporting version 1.7.71
http://imm.io/C7xj
joe42
Post by joe42 » Sun Aug 26, 2012 9:24 pm
DJRumpy wrote:Mine is reporting version 1.7.71
http://imm.io/C7xj
That's weird. When did you download it?
I'm wondering if maybe you got a pre-release version somehow. I guess it is supposed to look like "1.7.7.1" which makes me think that it is a slightly updated version of 1.7.7
DJRumpy
Post by DJRumpy » Sun Aug 26, 2012 9:33 pm
Romansh
Post by Romansh » Sun Aug 26, 2012 10:01 pm
Mac OS X version is 1.7.71:
[UPDATED] 1.7.7 was broken on Mac OS X
setarip_old
Post by setarip_old » Tue Aug 28, 2012 8:12 pm
@Romansh
Where on this website (makemkv.com) can one locate Mac v.1.7.71 for download?
I ask because all links on the homepage and forum pages appear to link only to v.1.7.7...
DJRumpy
Post by DJRumpy » Tue Aug 28, 2012 8:17 pm
The link shows the older version, but in reality is the .71 version.
jhodgesatmb
Post by jhodgesatmb » Thu Aug 30, 2012 9:45 pm
I have a retail set I bought from Amazon (as all my titles). I have 9 titles over 39 GB:
00004.mpls, 42.1 GB, 2:23:32, 16 Ch, t00.mkv (jumped backward in scenes a few times)
00007.mpls, 42.0 GB, 2:23:02, 16 Ch, t01.mkv
00010.mpls, 42.3 GB, 2:24:01, 16 Ch, t02.mkv
00044.mpls, 42.0 GB, 2:23:04, 16 Ch, t03.mkv
00076.mpls, 41.8 GB, 2:22:33, 15 Ch, t04.mkv (as recommended, I am going to try this next)
00234.mpls, 42.0 GB, 2:23:02, 16 Ch, t05.mkv
00321.mpls, 39.6 GB, 2:14:45, -- Ch, t06.mkv
00352.mpls, 42.1 GB, 2:23:30, 16 Ch, t07.mkv
00526.mpls, 42.1 GB, 2:23:32, 16 Ch, t09.mkv
Everything else on the disk was either skipped by MkMKV or was too small/short to consider a main title.
But this is still way too large. I encoded all of them and sent the first two over to my mini. Only after the first test did I think to come to the forum to see if anyone had had the same problems - which you have and I appreciate.
Tribal Spaceman
Post by Tribal Spaceman » Tue Sep 04, 2012 12:37 pm
Well I can confirm that it isn't
00017.mpls
00070.mpls
00085.mpls
00997.mpls
Has anyone else got any definite no's?
DJRumpy
Post by DJRumpy » Tue Sep 04, 2012 12:49 pm
Yes. Anything that's not 2:22:33 ;)
It really is as simple as popping the disc into your player and looking at the duration in the chapter selection menu.
Tribal Spaceman
Post by Tribal Spaceman » Tue Sep 04, 2012 1:26 pm
DJRumpy wrote:Yes. Anything that's not 2:22:33 ;)
I play all my movies through WinDVD BD. Is it straightforward in that?
DJRumpy
Post by DJRumpy » Tue Sep 04, 2012 6:38 pm
It was for me. I had to go to the chapter selection menu since my Blu-Ray player didn't show the duration in the digital display on the front of the player. If your BD disc is like mine, the chapter selection screen in your BD menus should display the movie duration though.
I need to crack open my BD player manual to see if I can change the display to show the duration rather then the 'time played'.
