Got this error with Another Earth today. Converted the secondary feature with no problem, but this keeps showing up with the main feature.
Mac OSX 10.6.8, MKV 1.7.7, LG BD.
First time I've gotten this message, but it's also the first time I've tried 1.7.7
Any ideas?
						Another Earth: copy complete, 0 titles saved, 1 failed
				stevesixty8
Re: Another Earth: copy complete, 0 titles saved, 1 failed
What errors are showing up in the log? (You DO have debugging turned on, right? And you're going to submit the debugging log when you come back online to check this thread, right?)
				stevesixty8
Well, no I didn't have the debugging log turned on. Since my problem wasn't either of these: "Program fails to open a disc or crashes, what should I do?", I didn't click on that link on the help page.
But if that's is what I needed to do, here it is:
Debug log started at Fri Aug 24 01:53:04 2012 , written by MakeMKV v1.7.71 darwin(x86-release)
001005:0000 MakeMKV v1.7.71 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/stevesixty8/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVR-K06A Q624" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE06LU11 YP01" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 2 at 0*D@[@0TV$@)^y@;:121268719
DAFD=PAAAADAAAAEABDQEEAQEBAUFERTAzMTIgAQoADEZEQwA=
DCE=vIM/LAjRj9hpxHUWShAzomTvlOBHyaqae230Fod1E2Zc9JtSGaa4n0VFdTHeppSx2jyWKtzc9sh9AvlewIVxjPeoS/BI/QrF7EVlL4yrxnUin54hJd8/fcVFb0LObimm1d6yXXb+aBIjD3m7jgIPtfaNsBXsl2nH6Q==
003317:0000 Loaded 71 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=F09F10050486E2D8FD755ED660E098F167CD3425
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00201.mpls has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00801.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003307:0000 File 00408.mpls was added as title #1
003025:0000 Title #00417.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00418.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00419.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00420.mpls has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00421.mpls has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00422.mpls has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00423.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00059.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00500.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00501.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00502.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00505.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00107.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00201.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00077.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00400.m2ts was added as title #2
003307:0000 File 00401.m2ts was added as title #3
003025:0000 Title #00331.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00402.m2ts was added as title #4
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00330.m2ts was added as title #5
003307:0000 File 00332.m2ts was added as title #6
003025:0000 Title #00351.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00403.m2ts was added as title #7
003307:0000 File 00404.m2ts was added as title #8
003307:0000 File 00405.m2ts was added as title #9
003307:0000 File 00406.m2ts was added as title #10
003307:0000 File 00407.m2ts was added as title #11
003025:0000 Title #00424.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 12 titles into directory /Users/stevesixty8/Movies/Another_Earth
001003:0020 DEBUG: Code 1073741829 at O~qi4Pvt>_bJtRoO:29393953
002003:0000 Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '5092995072'
001003:0020 DEBUG: Code 0 at XF*/LI/0.b#Na4s&o6?f:121262739
001003:0020 DEBUG: Code 0 at Gb[l@"eSGeM1"HOkHb\m:121261681
001003:0020 DEBUG: Code 0 at XF*/LI/0.b#Na4s&o6?f:213130743
001003:0020 DEBUG: Code 2486814 at XF*/LI/0.b#Na4s&o6?f:29393332
001003:0020 DEBUG: Code 0 at dhH)J44#,B\KeU&I37T=#:29397955
005003:0000 Failed to save title 0 to file /Users/stevesixty8/Movies/Another_Earth/Another_Earth_t00.mkv
AV sync issues in /Users/stevesixty8/Movies/Another_Earth/Another_Earth_t01.mkv
AV sync in 1 at 0:00:03.003 (5ms) : encountered overlapping frame, audio skew is +5ms
AV sync in 1 at 0:01:30.090 (17ms) : encountered overlapping frame, audio skew is +22ms
AV sync in 1 at 0:01:32.884 (21.541ms) : encountered overlapping frame, audio skew is +43.541ms
AV sync in 1 at 0:01:32.928 (32ms) : 1 frame(s) dropped to reduce audio skew to +11.541ms
AV sync in 1 at 0:02:59.137 (19.166ms) : encountered overlapping frame, audio skew is +30.708ms
AV sync in 1 at 0:03:02.098 (14.708ms) : encountered overlapping frame, audio skew is +45.416ms
AV sync in 1 at 0:03:02.144 (32ms) : 1 frame(s) dropped to reduce audio skew to +13.416ms
AV sync in 1 at 0:03:26.748 (22.375ms) : encountered overlapping frame, audio skew is +35.791ms
AV sync in 1 at 0:03:26.784 (32ms) : 1 frame(s) dropped to reduce audio skew to +3.791ms
AV sync in 1 at 0:03:29.751 (5ms) : encountered overlapping frame, audio skew is +8.791ms
AV sync in 1 at 0:05:06.639 (7.541ms) : encountered overlapping frame, audio skew is +16.333ms
AV sync in 1 at 0:05:09.642 (5ms) : encountered overlapping frame, audio skew is +21.333ms
AV sync in 1 at 0:06:58.084 (6.333ms) : encountered overlapping frame, audio skew is +27.666ms
AV sync in 1 at 0:07:01.254 (30.166ms) : encountered overlapping frame, audio skew is +57.833ms
AV sync in 1 at 0:07:01.312 (32ms) : 1 frame(s) dropped to reduce audio skew to +25.833ms
AV sync in 1 at 0:07:46.799 (22.5ms) : encountered overlapping frame, audio skew is +48.333ms
AV sync in 1 at 0:07:46.848 (32ms) : 1 frame(s) dropped to reduce audio skew to +16.333ms
AV sync in 1 at 0:07:49.802 (5ms) : encountered overlapping frame, audio skew is +21.333ms
AV sync in 1 at 0:09:08.172 (30.041ms) : encountered overlapping frame, audio skew is +51.375ms
AV sync in 1 at 0:09:08.224 (32ms) : 1 frame(s) dropped to reduce audio skew to +19.375ms
005004:0080 11 titles saved, 1 failed
005037:0204 Copy complete. 11 titles saved, 1 failed.
Application exited at Fri Aug 24 02:16:28 2012
As you can see, in this case I just decided to try to convert the entire disc, and got everything EXCEPT the main feature. The disc itself plays just fine in 2 stand-alone players and can be played through the Mac Blu-Ray player program, so I know that the disc is okay and that the LG drive is reading it completely. Just don't know what the SCSI error is.
Put the disc in the drive and click the "backup" button at the TOP of the first screen (note this is NOT the regular big button you press).
Pay attention to the log, if the disc is damaged you'll receive hash check errors.
