Failed to rip title 0 (i.e. the opening episode wherein everything is explained! )
Debug log started at Fri Jul 13 23:05:59 2012 , written by MakeMKV v1.7.6 darwin(x86-release)
001005:0000 MakeMKV v1.7.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/captain/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRAM GP08LU30 1.00" opened in DASPI v1.3 mode.
003025:0000 Title #0 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=1 pgcn=1 hash=919C4B167DF1C895
003028:0000 Title #1 was added (6 cell(s), 0:22:46)
Title skip vts=2 pgcn=1 hash=C9FD09AFBDCDD743
003028:0000 Title #2 was added (6 cell(s), 0:22:47)
Title skip vts=3 pgcn=1 hash=8F7ECAEE602259DD
003028:0000 Title #3 was added (6 cell(s), 0:22:47)
Title skip vts=4 pgcn=1 hash=D61C7CA6B9237FF9
003028:0000 Title #4 was added (6 cell(s), 0:22:47)
Title skip vts=5 pgcn=1 hash=DD21C0A71AF7FA5A
003028:0000 Title #5 was added (6 cell(s), 0:22:46)
Title skip vts=6 pgcn=1 hash=A990BB81F131931D
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=7 pgcn=1 hash=CF3512314FB7CB11
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6/0/1 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 4-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6/0/2 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 5-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6/0/3 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 6-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6/0/4 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 8-end were skipped due to cell commands (structure protection?)
003025:0000 Title #6/0/5 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Users/captain/Movies/Pr?teaR - Disc_1
001003:0020 DEBUG: Code 0 at |V4182.7w<l=YOyAoz :121264027
vobs=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
001003:0020 DEBUG: Code 0 at |V4182.7w<l=YOyAoz :213130674
001003:0020 DEBUG: Code 0 at 39Y]&sSnp8dS:4ZuT+L":121262532
001003:0020 DEBUG: Code 13060 at 39Y]&sSnp8dS:4ZuT+L":29393332
005003:0000 Failed to save title 0 to file /Users/captain/Movies/Pr?teaR - Disc_1/Disc_1_t00.mkv
005004:0080 0 titles saved, 1 failed
This is a retry log for just title 0. The other four titles previously ripped fine. This fail on title0 is repeatable.
OSX Mountain Lion may be the culprit.
Pr?teaR - disc 1
Re: Pr?teaR - disc 1
Well, not sure about whether Mountain Lion could be the culprit... But would still love to see MakeMKV rip this disk properly.
The developers don't visit the forums every day, so be patient. They will work their magic as soon as they can!
Have a similar problem with La Meglio Gioventu NL disk also working on Mountain Lion. Also have a Mac Mini Lion and will try there to see if that makes a difference.
DEBUG: Code 5 at ud$#RFF?%rm`wab~CTm:121266856
DEBUG: Code 149 at ud$#RFF?%rm`wab~CTm:29399036
DEBUG: Code 7 at ud$#RFF?%rm`wab~CTm:213135389
DEBUG: Code 0 at dhH)J44#,B\KeU&I37T=#:29397955
Failed to save title 0 to file /Users/stefaandegryse/Movies/MakeMKVOut/La_Meglio_Gioventu_(2003)_DISK_1_t00.mkv
Do this:
http://www.makemkv.com/faq/item/8
My test with the exact same DVD on a Mac Mini with Lion produced the same error. Guess we can exclude a ML specific problem.
Thx crowfax, i'll follow-up on it. Strange as this is a rather new DVD and heck even never used ... too much movies, too little time
- Contact:
Should be fixed in 1.7.7
