Treasure Sierra Madre
This blu-ray seems to process and complete but the resulting files won't play in Kiwk media nor can I open them in VideoReDo h.264. DVRMSToolkit complains that no filter can be found for this file.
- MakeMKV_log.txt
- (4.76 KiB) Downloaded 494 times
Re: Treasure Sierra Madre
I've tried this several more times, changing audio files, only selecting the movie, etc. The .mkv will play in power dvd 10 normally, it will not open in videoReDo, it will not decode in dvrmstoolkit, it will open in Nerovision without sound and you can play it but you cannot export or make a blu-ray from it.
It's probably the encoding of the files on the disc, not MakeMKV's fault. I had a BITCH of a time getting a copy of Christina, Barcelona that would play. I think it was a VC-1 (Micro$**t codec) encoded. Check the codec on TotSM. If it's VC-1, there's your problem. Just don't ask to see my badges!
Yes it is VC-1; but I think I've seen that before....what was different this time is that the MKV would play in Nerovision without sound, would not play in Nero Kwik Media and PowerDVD8 updated twice and then installed PowerDVD10 before the disc or the MKV would play....captain wrote:It's probably the encoding of the files on the disc, not MakeMKV's fault. I had a BITCH of a time getting a copy of Christina, Barcelona that would play. I think it was a VC-1 (Micro$**t codec) encoded. Check the codec on TotSM. If it's VC-1, there's your problem. Just don't ask to see my badges!
There must be a new codec but I can't find any update in the library for ffmpeg.
How long has this been lurking out there or is it something that WB just started using?
Here's part of the script from DVRMSToolkit
MEncoder Sherpya-SVN-r29355-4.5.0 (C) 2000-2009 MPlayer Team
success: format: 0 data: 0x0 - 0x5ff0e70d
[mkv] Track ID 1: video (V_MS/VFW/FOURCC), -vid 0
[mkv] Track ID 2: audio (A_DTS) "1/0", -aid 0, -alang eng
[mkv] Track ID 3: subtitles (S_HDMV/PGS), -sid 0, -slang eng
[mkv] Will play video track 1.
Matroska file format detected.
VIDEO: [WVC1] 1920x1080 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) -->> the data rate looks wrong
[V] filefmt:31 fourcc:0x31435657 size:1920x1080 fps:23.976 ftime:=0.0417
Opening audio decoder: [libdca] DTS decoding with libdca
AUDIO: 48000 Hz, 2 ch, s16le, 768.0 kbit/50.00% (ratio: 96000->192000)
Selected audio codec: [dts] afm: libdca (DTS-libdca)
PACKET SIZE: 2048 bytes, deltascr: 43885
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [harddup]
Opening video filter: [expand w=1920 h=1072]
Expand: 1920 x 1072, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
Opening video filter: [scale w=1920 h=1086]
Opening video decoder: [dmo] DMO video codecs
IMediaObject ERROR: 00D90640 could not open DMO DLL (0x0 : 0)
Failed to create DMO filter
You need to upgrade/install the binary codecs package.
Go to http://www.mplayerhq.hu/dload.html
VDecoder init failed : (
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
It is VC-1 in the MS format. But the audio shows as DCA....I know I've done other VC-1 titles but this one is a stumper.
Hooray! makemkv.com is back!
I had this problem with "Vicky, Christina, Barcelona" blu-ray, and I recall it being a VC-1 problem, not a makemkv problem.
