Glee - season 3 discs
captain
Post by captain » Thu Aug 16, 2012 8:02 pm
MakeMKV is getting stuck at "Reading Disc information", spitting out the below after several minutes, then ripping seems to proceed, then crash. I'm guessing this is because a SVQ decryption block is needed...?
DEBUG: Code 2281701379 at %Ph)t4f3oW{qD]&A:213133917
Downloading latest SVQ(s) to [~].MakeMKV ...
Loaded 94 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at !Ug24E3Xc/F1?n&w:29400531
DEBUG: Code 0 at !Ug24E3Xc/F1?n&w:29398254
DEBUG: Code 0 at !Ug24E3Xc/F1?n&w:213139690
Failed to process BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at <oC[3FKf5]5A['6FUl:121265706
Saved BD+ dump file as [~]/.MakeMKV/dump_Glee__Season_3_Disc_2_AFC87871900A54DE.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
DEBUG: Code 0 at lJ>y2],Q&"M*h\l*:29396897
Holy Crap! I certainly wouldn't put it past Sony (et al.) to scan all drives on my network and send themselves a nice little report! http://www.makemkv.com/svq/
Anyway, I emailed the dump file to svq@makemkv.com
I hope that we can get decryption keys for Glee S3 soon! :-)
PS: All SVQ files will be downloaded each time MakeMKV is started, right? So quit-restart is all that's needed to check for SVQs that will work with these discs...?
PPS: Would it be helpful to submit another dump, using a different Blu-ray drive?
Re: Glee - season 3 discs
Post by mike admin » Fri Aug 17, 2012 12:12 pm
Please re-submit a dump made with 1.7.7 - it should be 20+ MB in size. Also, noone submitted the dump for disc 2 yes, only 1 and 3.
captain
Post by captain » Sat Aug 18, 2012 7:52 pm
Oh good grief... I'm an idiot! I swear I checked the version before I submitted the report. A suggestion for idiots like me: please make the About MakeMKV pop-up window text show up in GREEN if we are up to date and RED if we are not. ;-)
PS: I'll upload the SVQ dump files directly to you via PM on the site here. 30mb is too large for my email system.
PPS: ... or so I thought. It looks like email went through. Mike, please let me know if you didn't get the dump files, and I will try again to upload directly.
Adendum:
How long does it typically take for SVQ files to be updated, once dump files are submitted?
captain
Post by captain » Thu Aug 23, 2012 3:12 am
Is there any way of finding out whether new SVQs are ready, or not, without going and trying to rip the discs again? It would be nice to have an alert emailed, or pop up, or at least a comment on rip reports saying "yep, it works now".
PS: I emailed the dump files, and it looks like they made it past the 10mb email limit, despite being 30mb. :-)
captain
Post by captain » Tue Aug 28, 2012 12:08 am
Disc 3 fails too.
captain
Post by captain » Wed Aug 29, 2012 2:34 pm
and disc 4
BTW, the "Upload attachment" won't let me PM you the 30mb dump files, and I don't think they are really making it out via email, so there's not much I can do to help here. :-(
Romansh
Post by Romansh » Wed Aug 29, 2012 2:57 pm
Dropbox or Google Drive would work too…
captain
Post by captain » Thu Aug 30, 2012 5:44 pm
Great ideas, thanks! Now, if only I knew HOW to use such things....
Post by mike admin » Tue Sep 04, 2012 6:34 am
SVQ updated for all discs.
