hang when completeing mkv
nrdgalor
#1 Post by nrdgalor » Fri Oct 23, 2009 2:41 pm
hi, just downloaded makemkv and it seems to do what i need. the strange part is that when it finishes the file, the app just hangs and i have to kill the process. no more data is being written to the file (that i can see). i have left it overnight just in case it was finishing the file, but it did not help. this is what shows when i kill the app.
Debug log started at Fri Oct 23 13:04:10 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003036:000000:0000 Title #0 was added (29 cell(s), 1:54:21)
001012:000000:0020 FAILURE: Code 3221225485 at ,H_;aq s/brP|*uo:121267270
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory C:/Users/Administrator/Desktop/mkv
Lots of this line repeated
005005:000000:0000 1 titles saved
005036:000000:0104 Copy complete. 1 titles saved.
Application exited at Fri Oct 23 14:36:45 2009
Re: hang when completeing mkv
#2 Post by mike admin » Mon Oct 26, 2009 8:12 am
what kind of drive do you have and what OS are you running? The error seems to be related to your drive, but it is unclear. when app hangs does it look like "makemkv" application uses 100% cpu and "makemkvcon" uses 0% CPU in task manager?
cameraaction41
#3 Post by cameraaction41 » Mon Oct 26, 2009 9:11 pm
That's odd. I've never encountered this issue before....
nrdgalor
#4 Post by nrdgalor » Mon Dec 14, 2009 4:13 pm
hi, i've been away for some time. i was on vista sp2 with the above issue. my laptop has an Otiarc ad-7530a. the process does go down to 0% usage, but the app does not close. i copy the file from it's location to test, and it is fully copied @ a 1:1 ratio, no compression. then i kill the app. thanks,
nrdgalor
#5 Post by nrdgalor » Mon Dec 14, 2009 6:27 pm
ok, tested it today on win7 with 1.4.9 and it works like a charm. thanks. on a side note, this does a 1:1 conversion of the source, correct?
