3D Blu-Rays not converting as 3D?
CIncyman12
Post by CIncyman12 » Thu Aug 16, 2012 4:30 pm
I've been searching around and there are alot of old threads about this but nothing current.
When running MakeMKV on my 3D Blu-Rays I find the track with the the Mpeg4-MVC-3D and I select that file with that stream selected and let makekv
run through it's process, which it completes successfully, I then process that with handbrake and try to feed it to my AppleTV which plays it as 2D.
I've checked the resulting mkv files with mediainfo and they don't seem to indicate that the file is a 3D format.
Am I missing a step here? I've tried several Harry Potter movies, and How to Train Your Dragon but no luck.
Any help is appreciated?
crowfax
Re: 3D Blu-Rays not converting as 3D?
Post by crowfax » Thu Aug 16, 2012 5:59 pm
Handbrake does not support 3D.
CIncyman12
Post by CIncyman12 » Thu Aug 16, 2012 7:00 pm
Hmmm didn't think handbrake cared but even so before I covert them with Handbrake mediainfo does not show the files as 3D.
crowfax
Post by crowfax » Thu Aug 16, 2012 7:14 pm
So far as I know the only software that will play back a full 3D MKV file as created by MakeMKV is PowerDVD, however as I do not have a 3d display, I have never tested it.
I know some of the regular forum members have, I'm sure one of them will comment soon.
CIncyman12
Post by CIncyman12 » Thu Aug 16, 2012 11:43 pm
If MakeMKV is grabbing the 3D content it should just be streamed through my AppleTV to my Sony 3D TV which should sense the 3D content and display it.
crowfax
Post by crowfax » Thu Aug 16, 2012 11:57 pm
That's a playback issue. It has nothing to do with MakeMKV.
CIncyman12
Post by CIncyman12 » Fri Aug 17, 2012 12:05 am
Except according to mediainfo I'm not getting my 3D stream in my file from makemkv even though I checked the box for the 3D stream.
crowfax
Post by crowfax » Fri Aug 17, 2012 12:12 am
Here's a fun test for you.
Rip the same title twice, once with 3D selected, and once without 3D selected.
Is the one made with 3D selected bigger?
If so, the 3D data is in the file and you can disregard Mediainfo.
