file naming conventions?????/
bandyaker
#1 Post by bandyaker » Fri Aug 03, 2012 1:39 pm
Hi all I am new so excuse my ignorance.
I have just built a HTPC
I have installed XMBC
I Have installed MakeMkv.
I now want to rip my Blu-Ray/DVD collection to my Hard Drive and into a library on XBMC.
I have ripped my first BD 'Earth' using Make Mkv and am now looking at files such as ,Aux Data,Back up,Clipine,Jar etc etc etc.
I now want to open my ripped Blu-Ray in XMBC.....
Now its at this point I am totally confused :?
Movie naming conventions?
How and where do I enter this info ,such as \Movies\HD\Full Movie Name\movie_blu_ray.mkv ?
I am really sorry if I being a little dumb here .
Anything else I need to here?
Any help would be appreciated here,the mind is not as young as it once was.
best regards
NB
I have just ripped 'Casino Royal' using Makemkv .I am now left with 7 files ,do I have to create a folder for these and name it (as above) in Windows or is it something I do in XBMC?????
Smithcraft
Re: file naming conventions?????/
#2 Post by Smithcraft » Fri Aug 03, 2012 5:14 pm
You copied the BD. Try ripping just the parts that you want. Let us know what part of http://www.makemkv.com/onlinehelp/ is giving you problems.
For naming, lets say you did The Avengers, that just came out.
You could either do: \Movies\HD\The Avengers (2012).mkv
or: \Movies\HD\The Avengers (2012)\The Avengers (2012).mkv
SC
bandyaker
#3 Post by bandyaker » Fri Aug 03, 2012 5:51 pm
Thanks for your reply.
After a afternoon of head scratching I have found out how to just rip the parts I want.
Do you name the file in the 'Output file' box or is this done in XBMC?
The majority of problems I am having are in XBMC and getting that to see the files and configuring the scraper etc.
I guess it will become clear eventually ..
Smithcraft
#4 Post by Smithcraft » Fri Aug 03, 2012 6:56 pm
Name them after you rip them, then place them in the folder for XBMC.
SC
