I have been going through my collection of DVDs and hit on 4 DVDs that would fail on attempts to conversion...
1) Harry Potter The Order of the Phoenix
2) Halloween VI The Curse of Michael Myers
3) Gridiron Gang
4) Friday
Is there something else I should try for these?
DVD converting errors!
Re: DVD converting errors!
I found another one...
5) House of wax
5) House of wax
Without seeings the logs, no one here can even start to guess at the issue. The most likely reason for them to fail however, is a dirty/damaged/poorly manufactured disc.
I ran into the same problem with Halloween 6, four failed attempts. I actually ripped it using dvdfab two days ago so the disk has to be good enough for that. I cleaned it anyways and attempted to rip it yet again.
Here is the log from the scan.
Analyzing seamless segments gets to about 35% in 25 seconds and then I get a dialog box that says "Fatal error occured, program will now exit.". the dialog box has only an "ok" button. after pressing that the program shuts down. I can see the log window and what is there is below.
MakeMKV v1.7.7 win(x64-release) started
Complex multiplex encountered - 3 cells and 656 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #0 was added (18 cell(s), 1:27:45)
Complex multiplex encountered - 3 cells and 654 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Angle #2 was added for title #0
Title #1 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory G:/Media/Rip/mkv/Halloween 6 The Curse of Michael Myers - 1995 720p AC3
I decided to get someone else's dvds and see if the problem recurs... To my surprise, several of them are ripped successfully with MakeMKV which makes me think it is a bad DVD issue (scratches, etc). However there is one DVD which I think has a problem with MakeMKV which is called Shoot Em Up. I tried two different DVDs and two different DVD burners and the problem is that it never "finds" the correct title. The largest size title is 1 GB and is only 26 minutes long... There are no errors, so I am not sure why MakeMKV can't find the title.. anyone know?
