MakeMKV just hangs for me
Steffen
#1 Post by Steffen » Tue Jul 24, 2012 7:14 pm
Hi there,
when I start up MakeMKV (with/without admin privileges/no medium inside my drives), I just get this screen. I can only terminate it (CTRL-B).
I have installed two optival drives:
R:\ PLEXTOR DVD-ROM PX-130A ATA Device
S:\ PIONEER BD-RW BDR-202
They're working without any problems using Windows 7 Pro x64 with 8 GB RAM.
Any help is much appreciated.
Thank you very much.
Re: MakeMKV just hangs for me
#2 Post by mike admin » Wed Jul 25, 2012 9:39 am
Apparently there is a problem with PLEXTOR drive. Just to check, can you try disabling the drive in device manager and see if MakeMKV will still hang?
Steffen
#3 Post by Steffen » Wed Jul 25, 2012 11:45 pm
Thank you, Mike... this workaround really works! :)
If I disable the Plextor drive, I can start MakeMKV successfully.
