House Season 6: Operation result is incorrect
actionsuperhero
Post by actionsuperhero »
I can't tell if this is just a bad disc or not: I don't have any other hardware and software to try, and not a lot of other discs, although MakeMKV has ripped every other disc in this set OK. An error comes up while saving title 01 on disc 4 of House, Season 6 (US Blu-Ray). A similar error occurs whether I try to save the title, back up the disc with decryption, or back up without decryption.
Debug log started at Fri Jul 20 14:36:26 2012 , written by MakeMKV v1.7.6 linux(x64-release)
001005:0000 MakeMKV v1.7.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/rhd/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/media/intmovies/HOUSE_S6_D4"
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=A50lJSWKJDi+Ph4JU271RaKTjGTDwOG3yVaqYHN9zVPCjdczKf3LUYS+aS22OLJ5nVaqLiq2A4Kz55nfMRWiooJ3oL0bphpm90Wi4FxBrkG0cXrKvtnWMs8PYhO+W1ILUKUq767ywda5d4LZh3Aa/WjMLdt3wo8nyg==
DCE=JSUlJSVt0zjtr9zRBa1D8QhNxYR8qOUR841tQWSEXxaXysCjICYLQHBjP9hMbP3D8IfOwgpo0lHlcpaUMoQP0bmzQtDfqNb50HgRAI6LrL5PVsucvFRsQfdUo70IzUnQp40xMJZaYsnFbzsZpD97xrkN1mFSTUFbHQ==
001003:0020 DEBUG: Code 16 at z~@Ui(3\Cwp0)FT5WFD@:29395149
001003:0020 DEBUG: Code 0 at .IR#C}$He3Zh.sO&R-A6Aso:213130122
001003:0020 DEBUG: Code 2 at rlXR';dOngTIM>O1:121268719
002003:0000 Error 'Internal error - Operation result is incorrect (234)' occurred while reading 'BD-RE ASUS BW-12D1S-U E102' at offset '1822423040'
001003:0020 DEBUG: Code 117637354 at (4f1,hU0.RtS(?dHM,:121262670
001003:0020 DEBUG: Code 117637354 at (4f1,hU0.RtS(?dHM,:121262923
001003:0020 DEBUG: Code 0 at *$QO'5Tr#brj}Qnvu-vS:29398208
001003:0020 DEBUG: Code 0 at *$QO'5Tr#brj}Qnvu-vS:29406419
005069:0080 Backup failed
005080:0204 Backup failed.
Re: House Season 6: Operation result is incorrect
Post by mike admin »
This is likely a physically damaged disc.
