not exactly an error
peteyx
Post by peteyx »
Every single Blu-ray that I rip with makemkv has the HD 5.1 audio unchecked by default. I have to make sure to check that option, otherwise all I will get is 2 channel stereo. Is there a way to have 5.1 automatically selected?
BlackDragon24
Re: not exactly an error
Post by BlackDragon24 »
peteyx wrote:Every single Blu-ray that I rip with makemkv has the HD 5.1 audio unchecked by default. I have to make sure to check that option, otherwise all I will get is 2 channel stereo. Is there a way to have 5.1 automatically selected?
The HD is unchecked by default because most standalone players cannot decode DTS-MA. Some can do TrueHD but not all. By default the Core of the DTS track is checked, which should give you full 5.1 sound. TrueHD will have the 448/640kbps AC3 track checked by default, which will also give 5.1 sound.
peteyx
Post by peteyx »
I think I follow, but when I view the list of movies in XBMC, those that I didn't check show up as 2 channel stereo.
Smithcraft
Post by Smithcraft »
Try using MediaInfo to see what is in the file.
SC
