How to train your dragon fails
iqindy
#1 Post by iqindy » Fri Jul 13, 2012 8:38 pm
It either crashes during initial load and says must close or says 0 titles saved. Thanks for the help!
Debug log started at Fri Jul 13 20:21:00 2012 , written by MakeMKV v1.7.6 win(x64-release)
001005:0000 MakeMKV v1.7.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Matt/MakeMKV_log.txt
005050:0000 Evaluation version, 18 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
DCE=AZNmkMNmfcIUmAG0AzVP0mc5+zkLIEHUTUcn8a4VoP58bYVLbhALoGjC16rX5tHcGbzConozv2RWiCOTLUwPSFzN7ivISB1joiroV1umDYmBLyEUyNENLVY/K0gyAMo2Yg5wpVrWz2n4sUNhAHzQVckifkFPCD3piw==
DCE=bBbKU30duUzvu+fhykZLGEut3BrMK/vCbXe3paGV8WjjGrc/HMqHr460p/f++WfsUG/n8MfxljmXk4AzvT1fH2qZP8L1xYM7ED9/J4OoWULb6dNDqT/62SczscGbnsX/2HB7QJ6AyitNfkkX3hu35A8IAJbdhtZhYw==
DISCID=A6EFC9C899377C53EDAC0A48E17152B29BD7379B
003025:0000 Title #00047.mpls has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00061.mpls was added as title #0
003025:0000 Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00086.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00101.mpls was added as title #1
003307:0000 File 00092.mpls was added as title #2
003025:0000 Title #00000.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #3
003307:0000 File 00013.m2ts was added as title #4
003307:0000 File 00014.m2ts was added as title #5
003307:0000 File 00022.m2ts was added as title #6
003025:0000 Title #00023.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00025.m2ts was added as title #7
003025:0000 Title #00026.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00029.m2ts was added as title #8
003025:0000 Title #01000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00086.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00133.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 5rXjHbeL9LNjgZzUrergB1E+:0
005014:0000 Saving 9 titles into directory c:\test\
001003:0020 DEBUG: Code 3 at H{<E*F46{T&O:Md $HTI1:213129892
005003:0000 Failed to save title 0 to file c:\test\/How_To_Train_Your_Dragon_t00.mkv
005003:0000 Failed to save title 1 to file c:\test\/How_To_Train_Your_Dragon_t01.mkv
005003:0000 Failed to save title 2 to file c:\test\/How_To_Train_Your_Dragon_t02.mkv
005003:0000 Failed to save title 3 to file c:\test\/How_To_Train_Your_Dragon_t03.mkv
005003:0000 Failed to save title 4 to file c:\test\/How_To_Train_Your_Dragon_t04.mkv
005003:0000 Failed to save title 5 to file c:\test\/How_To_Train_Your_Dragon_t05.mkv
005003:0000 Failed to save title 6 to file c:\test\/How_To_Train_Your_Dragon_t06.mkv
005003:0000 Failed to save title 7 to file c:\test\/How_To_Train_Your_Dragon_t07.mkv
005003:0000 Failed to save title 8 to file c:\test\/How_To_Train_Your_Dragon_t08.mkv
005004:0080 0 titles saved, 9 failed
005037:0204 Copy complete. 0 titles saved, 9 failed.
Application exited at Fri Jul 13 20:23:18 2012
kfreeb
Re: How to train your dragon fails
#2 Post by kfreeb » Fri Jul 13, 2012 11:25 pm
First off, I have this very title, (USA release) and it ripped without any problems, so here are a few questions for you to answer.
Can you rip most other Blu-rays without any problems? If you are having problems with other disks, then your blu-ray drive, (small chance) may be at fault, (failing.) If not, then is this the only blu-ray that is giving you problems? If yes, then it can only be a few things that are preventing you from ripping this blu-ray.
First, are you running MakeMKV 1.7.6? If not, update.
Is the optical side of the disk completely clean, no finger prints, foggy residue left on the surface, in other words totally clean. If yes, then the disk is probably defective. I've run into a handful of blu-rays, that would play fine in my set-top player for my TV but will not read in the blu-ray drive of my computer. I just took those disk back to were I purchased them and had them replaced.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
iqindy
#3 Post by iqindy » Sat Jul 14, 2012 3:35 pm
Thanks for the response.
Yes on 1.7.6
I have ripped many recently without any previous failures.
I don't see any physical problem.
If it isn't related to the title, then I guess I will need to try another disc.
Thanks.
