MakeMKV to slow, 104h for one BD
Calby
#1 Post by Calby » Thu Jul 12, 2012 6:43 pm
Hi guys.
I got MAC OS ML GM and I have one external samsung BD player.
When I try to ripp Cars MakeMKV tells me that it 'll take 104h =S
The movie file at the BD is only 24GB this most bee something wrong or what?
I got Macbook pro late 2011.
2,4GHz Intel Core i5.
8GB DDR3 ram 1333mhz
Force 3 SSD disc
Smithcraft
Re: MakeMKV to slow, 104h for one BD
#2 Post by Smithcraft » Fri Jul 13, 2012 10:08 am
Maybe the log would be of benefit to helping figure out what is wrong?
SC
Calby
#3 Post by Calby » Mon Jul 16, 2012 2:50 pm
The decryptionlog:
MakeMKV v1.7.6 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5970H 3APE" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS01" opened in OS access mode.
Evaluation version, 26 day(s) out of 30 remaining
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00698.m2ts' at offset '276922368'
Title #00134.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00647.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00029.mpls (angle 1) was added as title #0
File 00029.mpls (angle 2) was added as title #1
File 00024.mpls was added as title #2
File 00024.mpls(53) was added as title #3
File 00053.mpls was added as title #4
File 00072.mpls (angle 1) was added as title #5
File 00072.mpls (angle 2) was added as title #6
File 00074.mpls was added as title #7
Title 00077.mpls is equal to title 00072.mpls and was skipped
File 00671.mpls was added as title #8
File 00671.mpls(53) was added as title #9
File 00692.mpls was added as title #10
File 00692.mpls(53) was added as title #11
Title #00022.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00039.m2ts was added as title #12
File 00040.m2ts was added as title #13
File 00041.m2ts was added as title #14
File 00042.m2ts was added as title #15
File 00043.m2ts was added as title #16
File 00044.m2ts was added as title #17
File 00045.m2ts was added as title #18
File 00046.m2ts was added as title #19
Title #00052.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00203.m2ts was added as title #20
Title #00393.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00394.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00395.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00396.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00397.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00398.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00497.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00550.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00554.m2ts was added as title #21
File 00644.m2ts was added as title #22
File 00645.m2ts was added as title #23
Title #00662.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00663.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00664.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00665.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00666.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00667.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00669.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00671.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00673.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00675.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00677.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00679.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00681.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00683.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00685.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00687.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00689.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00691.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00693.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00695.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The information about the movie after I have selected what I want to ripp:
Title information
Source file name: 00074.mpls
Duration: 1:56:35
Chapters count: 31
Segment count: 28
Segment map: 668,696,670,697,672,698,674,699,676,700,678,701,680,702,682,703,684,704,686,705,688,706,690,707,692,708,694,709
File name: title07.mkv
Now it says it shod take 11h , reading speed 0,7x but my reader is 6x so whats wrong?
NutFlush920
#4 Post by NutFlush920 » Wed Jul 18, 2012 1:27 am
Could it be riplock? I recently bought the Samsung SE506AB USB drive. It claims to be 6X read spread but, I get about 2X consistently while ripping BR's.
Granted it doesn't take nearly as long as yours does but does take longer (about an hour). Your drives riplock may be even slower then mine is. Just a thought?
