Fringe Season 1 Region 2 Episode Problem
wyerd
Post by wyerd »
I'm using 1.7.6 and it doesn't split the the titles into individual episodes, only as one big 34.9GB chunk, 1-31 chapters.
How do I get each episode into a MKV?
NutFlush920
Post by NutFlush920 »
I had the same issue. This is just the way it's authored. You'll have to rip the large file to MKV then use another program like MKV Merge to split them into individual episodes.
The good news is its on a few discs like that if I remember correctly.
wyerd
Re: Fringe Season 1 Region 2 Episode Problem
Post by wyerd »
NutFlush920 wrote:I had the same issue. This is just the way it's authored. You'll have to rip the large file to MKV then use another program like MKV Merge to split them into individual episodes.
Ok thanks. I'll check out MKV Merge.
