I'm using 1.7.6 and it doesn't split the the titles into individual episodes, only as one big 34.9GB chunk, 1-31 chapters.
How do I get each episode into a MKV?
Fringe Season 1 Region 2 Episode Problem
- Capture.PNG (9.58 KiB) Viewed 9748 times
NutFlush920
I had the same issue. This is just the way it's authored. You'll have to rip the large file to MKV then use another program like MKV Merge to split them into individual episodes.
The good news is its on a few discs like that if I remember correctly.
Re: Fringe Season 1 Region 2 Episode Problem
Ok thanks. I'll check out MKV Merge.NutFlush920 wrote:I had the same issue. This is just the way it's authored. You'll have to rip the large file to MKV then use another program like MKV Merge to split them into individual episodes.
