How do I use the created files (s)?
Newbie here... I've just joined my first 2 mkv files and I've got an_FFTemp18EO_.avi file and an _FFTemp18EO_.avs file (combined size about 13MB compared to 7+GB of the two origianl files). Then I have another file with my specified name of about the correct joined size. I don't understand how these all work together. Please explain playback. Also, if I want to move the combined file, which of these file(s) do I move? If I click on the largest of the 3 files I get an error msg to set default file association... how do I do that? I really need some help, please!
- diamonds3.png (29.97 KiB) Viewed 7215 times
- diamonds2.png (20.78 KiB) Viewed 7215 times
- diamonds1.png (29.17 KiB) Viewed 7215 times
setarip_old
Re: How do I use the created files (s)?
Hi!
1) None of what you've posted here appears to have anything to do with MakeMKV (certainly not your ".avi"/".avs" problems)
2) None of what you posted here regarding your source material ("torrents", Usenet, uTorrents) appears to have anything to do with purchased original, commercial discs...
Thanks for your reply, setarip_old... The 2 mkv files I wanted to combine were part of a UseNet download and carried the .mkv extension. Are they somehow different from "purchased commercial discs?" Shouldn't MKVmerge handle this?
- Diamonds2.png (20.75 KiB) Viewed 7188 times
- diamonds.png (24.04 KiB) Viewed 7188 times
You'd have to go ask the developer of MKVmerge. This is the MakeMKV forum.weybrew wrote:Shouldn't MKVmerge handle this?
