Unfaithful (Blu-ray) - Some files convert, not others
jeffs
#1 Post by jeffs » Wed Jul 11, 2012 12:43 pm
Using MakeMKV 1.7.6 (GUI version). Converted the main movie (approx 35G) fine, and a number of other files; however, it failed to convert most of the "deleted scene" files which range in size from about 125M to 550M. I am using the trial version. I thought it might have to do with this so I copied the unconverted files (about 10 of them into another directory and tried again. No luck. What's very strange is that when I click the folder icon in MakeMKV and try to view the Blu-ray directory G:\BDMV\STREAM, "no" files are visible in the popup window. The only time conversion occurs is when I select the disc as a whole. And, there doesn't appear to be any rhyme or reason as to which m2ts files are converted and which aren't. And no m2ts files ever appear in the file selection popup window.
MakeMKV also took some m2ts files and concatenated them into a new file that has no twin on the Blu-ray. What is happening here?
Regards
