Copy complete. 0 titles saved, 1 failed.
problemss
Post by problemss » Tue Jul 10, 2012 7:03 am
I have a AVCHD iso file and the contents burned to a dvd. I am trying the iso and the dvd, but receive the same error message. It occurs after a couple second of the MKV process.
"Copy complete. 0 titles saved, 1 failed."
Here is the error log.
Debug log started at Tue Jul 10 06:23:58 2012 , written by MakeMKV v1.7.6 darwin(x86-release)
001005:0000 MakeMKV v1.7.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/xxxx/MakeMKV_log.txt
005042:0000 The program can't find any usable optical drives.
001003:0020 DEBUG: Code 0 at HE8@I+ITRVmV>ObMV:121262164
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003307:0000 File 00000.mpls was added as title #0
001003:0020 DEBUG: Code 233 at 0STkTH4NZnyfKwR36fROya8p:0
005014:0000 Saving 1 titles into directory /Users/xxxx/Movies/ROTJ_AVCHD
001003:0020 DEBUG: Code 2147483647 at 5L?U3wS:VP#J\qRdeTg:29393700
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file /Users/xxxx/Movies/ROTJ_AVCHD/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Jul 10 06:27:01 2012
setarip_old
Re: Copy complete. 0 titles saved, 1 failed.
Post by setarip_old » Tue Jul 10, 2012 10:19 pm
Hi!
As I posted in your earlier "DVD" sub-forum thread:
Try using only original, commercial DVDs and/or Blu-ray discs as your source material.
You'll stand a better chance of obtaining meaningful information at the MakeMKV Forum (and many others) - both because of ethical (and, perhaps, legal) reasons and because this will limit the possible reasons for your difficulty...
problemss
Post by problemss » Wed Jul 11, 2012 3:26 am
Unfortunately this file does not exist as a commercial dvd or blu-ray. It is a fan edit of the original VHS. I own the VHS so there are no legal issues.
Do you think this is something that can be done by MakeMKV or do I have to look at another utility to convert it to a MKV file?
problemss
Post by problemss » Wed Jul 11, 2012 4:28 am
I wasn't able to figure out how to do it with MakeMKV. So I used mkvtoolnix and it was able to convert the m2ts file I grabbed from the iso.
