Bad Ass with Danny Trejo Failed to process BD+ code
mickolas
#1 Post by mickolas » Tue Jul 10, 2012 2:41 am
MakeMKV v1.7.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Mick/MakeMKV_log.txt
Loaded 82 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at ewG,HL8B!3!eiV?I:29400531
DEBUG: Code 0 at ewG,HL8B!3!eiV?I:29398254
DEBUG: Code 0 at ewG,HL8B!3!eiV?I:213139690
Failed to process BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at RUF)h1|*4S7'}^,M:29402095
DEBUG: Code 0 at vdSAOq:7iMZqM4G;~u:121265706
Saved BD+ dump file as C:\Users\Mick/.MakeMKV/dump_Bad_Ass_208FD2F85FECBCFB.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
DEBUG: Code 0 at RUF)h1|*4S7'}^,M:29396897
crowfax
Re: Bad Ass with Danny Trejo Failed to process BD+ code
#2 Post by crowfax » Tue Jul 10, 2012 2:54 am
Email this file:
To support@makemkv.com
goingbust
#3 Post by goingbust » Tue Jul 10, 2012 4:46 am
I just received the same. The dump is 16 megs. My email client can't upload that!
crowfax
#4 Post by crowfax » Tue Jul 10, 2012 4:58 am
then put it somewhere like http://www.sendspace.com/ and send them the link to it.
setarip_old
#5 Post by setarip_old » Tue Jul 10, 2012 10:08 pm
@mickolas; @goingbust
Hi!
Did you? (as you should)
...please check http://www.makemkv.com/svq/ for updated program and SVQ files
