This Means War
divcss
This Means War
#1 Post by divcss » Sat Jul 07, 2012 12:55 pm
I have problems in encoding "This Means War" BD+.
Here is the corresponding dump file:
http://uploaded.to/file/u1thwn2e
Any suggestions?
setarip_old
Re: This Means War
#2 Post by setarip_old » Sat Jul 07, 2012 5:39 pm
Hi!
What SPECIFIC problems are you having?
ftz.de
Re: This Means War
#3 Post by ftz.de » Wed Jul 11, 2012 2:20 pm
I have the same problem. :(
@divcss: Have you mailed the dumb file to svq@makemkv.com, as described on http://www.makemkv.com/svq/ ?
@setarip_old: MakeMKV says:
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as ...
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
theforce
Re: This Means War
#4 Post by theforce » Thu Jul 12, 2012 11:43 am
I've also got the same problem, and I've email the tgz dump (using a different email address)
ephemeris
Re: This Means War
#5 Post by ephemeris » Thu Oct 11, 2012 5:20 pm
Still no workaround after three months? I submitted my dump file the week this disc came out. I just tried MakeMKV 1.7.7 (OSX) and it still fails.
setarip_old
Re: This Means War
#6 Post by setarip_old » Thu Oct 11, 2012 9:20 pm
@ephemeris
According to the list at the following forum link,you'll find that this title is one that has supposedly been "taken care of":
http://viewtopic.php?f=5&t=612#p1657
ephemeris
Re: This Means War - Problem resolved
#7 Post by ephemeris » Fri Oct 12, 2012 1:35 pm
Problem solved. Looks like my data directory was corrupt. I deleted everything so that when I launched MakeMKV it reloaded all the svq files.
setarip_old
Re: This Means War
#8 Post by setarip_old » Fri Oct 12, 2012 10:25 pm
@ephemeris
Glad to hear that you've resolved your problem ;>}
