I am tryng to convert a 46.6 GB iso file but as soon the program started I got the followin error.
"It appears that you have on-the-fly decryption software enabled. MakeMKV should process dis cs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable such software and restart the application."
Your help on how to fix it is really appreciated!!!
Decryption Error
Smithcraft
Re: Decryption Error
Give MakeMKV a try and see if it works.
SC
SC
aleito
I gave MakeMKV a try but it said 0 title saved, 1 failed. I verified the folder and nothing was saved inside it. How I know which 3rd party software needs to be disable?
crowfax
Run it on the original disc and not a ripped ISO.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
Dr Tom
Hi everyone,
I am having the same " on the fly decryption software" Disable it .
Disable what ? I don't have anything enabled except DVD FAB which is not open when using MKV ( 1.76).
I am trying to tip " the hurt locker" on blu-ray.
I tried MKV alone and got a buzzing noise halfway through the movie.
I then tried ripping to a folder with DVD-FAB, and then converting that to MKV.
Same error message.
What software is triggering this OTFD SFTW ?
Thanks,
TOM
Same error message.
Thanks,
TOM
BlackDragon24
Look inside the .iso file and see if there is an "ANY!" folder somewhere. Delete it.
