makemkv vs. eac3to -- different sized video streams?
woody777
Post by woody777 »
To make a long story short... my AnyDVD subscription is up and I'm trying to decide whether to renew it or buy MakeMKV... basically MakeMKV vs. AnyDVD/eac3to/MKVMerge. Anyway... I've been doing some experimenting.
If I rip using MakeMKV and then demux with MKVExtract, the video stream is always smaller than with eac3to.
If I rip using eac3to (ClownBD gui, but only demuxing with eac3to), the video stream is always bigger than with MakeMKV.
All other streams (audio & subs) are the exact same size. Now, I'm only talking a few hundred bytes here, but why are they different at all? Shouldn't the elementary streams be identical?
woody777
Re: makemkv vs. eac3to -- different sized video streams?
Post by woody777 »
Also, thinking it was maybe something to do with the header, I even set header compression to "none" in MKVMerge with no effect on any streams after I extracted them again using MKVExtract.
woody777
Post by woody777 »
Nothing? I wonder if this is an issue on my end. Has nobody noticed this before?
Post by mike admin »
Most video-streams are zero-padded for bit rate control. MakeMKV removes zero-padding, eac3to (as many tools) doesn't.
woody777
Post by woody777 »
Thanks Mike. I'm far from an expert on zero-padding, but the way I understand it, shouldn't the size of the file remain identical?
nfusion
Post by nfusion »
zero padded means
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
All those zeros still take up KB, if makeMKV strips those 000000000000000000000000000000 then you save KB.
Romansh
Post by Romansh »
woody777 wrote:Thanks Mike. I'm far from an expert on zero-padding, but the way I understand it, shouldn't the size of the file remain identical?
As nfusion pointed out: no. Padding -> additional data, additional data -> increased file size.
woody777
Post by woody777 »
Thanks guys! That explains it!
