Flac transcoding crashing
Icanseestars
I've been trying out the Flac transcoding but haven't had any luck so far, seems to crash every time I try. I've changed builds of ffmpeg, different Blu-ray's and it makes no difference (audio track selected was TrueHD).
Running Windows 7 64-bit, used latest ffmpeg from zeranoe, it just crashes, asks to send error report then MakeMKV cancels the job.
I've attached the log if that can help.
- MakeMKV_log.txt
- (3.86 KiB) Downloaded 1904 times
- Contact:
Re: Flac transcoding crashing
As of 1.7.7 MakeMKV comes with its own ffmpeg executable. Just clear the ffmpeg location in preferences and it'll revert to using builtin mmffmpeg.
I have cleared the FFMPEG location in the settings but with 1.7.7 each time I try to convert to FLAC I get: "Unable to execute external program 'ffmpeg' as its path is not set in preferences". :/
MakeMKV 1.7.7 on 64-Bit Linux. BTW: What is the location of the mmffmpeg binary? Is it in the MakeMKV binary?
- Contact:
Linux is a special case - mmffmpeg comes pre-compiled only on Windows and Mac, for Linux you have to compile one yourself from source.
@mike admin:
Will your 24 bit patch get into upstream in time? Have you sent the patch so the ffmpeg developers?
So long, a pre-compiled binary of mmffmpeg would be very handy on Linux too, because I have compiled and installed it and I'm still getting only 16 bit FLACs... Maybe I miss something, I don't know. :/
Justin (Ruggles) has a patch for 24-bit FLAC which looks a tad cleaner that the MakeMKV one. It's mostly ready and just needs cleanup, but it's not terribly high on his priority list.holunder2 wrote:@mike admin:
In any case, since you can build from source, may I suggested applying the MakeMKV patch?
http://www.makemkv.com/download/ffmpeg/
Hey,
the result that I still got 16 bit FLAC was as I had installed the mmffmpeg over my system's ffmpeg and I suspect this was the problem. So I made a fine Arch package and installed it into /opt and wrote into the FFMPEG location field in MakeMKV. When I run this in a terminal it works. But in MakeMKV the program freezes at conversion and even doesn't work. Then I tried to put this into a wrapper:
made it executable and set the FMPEG location to /home/username/.MakeMKV/mmffmpegwrapper.sh but MakeMKV still freezes at conversation.
I didn't applied the mmffmpeg patch from http://www.makemkv.com/download/ffmpeg/ because it is already integrated in the main archive. I think so.
So, now I can't use mmffmpeg although it is installed. :/
EDIT: Oh, a friend told me, I need to set $@ at the end of the line, so
works!!
The wrapper is necessary, but it works now and I get 24 bit FLACs, yeah!
LD_LIBRARY_PATH=/opt/mmffmpeg/lib /opt/mmffmpeg/bin/ffmpegCode: Select all
/usr/lib/ld-2.16.so --library-path /opt/mmffmpeg/lib /opt/mmffmpeg/bin/ffmpegCode: Select all
#!/bin/sh
[command 1 / command 2]I didn't applied the mmffmpeg patch from http://www.makemkv.com/download/ffmpeg/ because it is already integrated in the main archive. I think so.
#!/bin/sh
LD_LIBRARY_PATH=/opt/mmffmpeg/lib /opt/mmffmpeg/bin/ffmpeg $@Re: Flac transcoding crashing
Hey, I have sent the patch to ffmpeg devs, regardless of @Romansh's hint on another patch. They ask for the name of the author, please respond: http://ffmpeg.org/trac/ffmpeg/ticket/210
- Contact:
This patch is Public domain. No copyright is claimed. Feel free to give a link to this page.
- Contact:
When building ffmpeg, pass "--disable-shared --enable-static" to configure and you won't be needing any wrapper. The ffmpeg executable will be self-contained with no dependencies on any (non-system) libraries.holunder2 wrote:works!!The wrapper is necessary, but it works now and I get 24 bit FLACs, yeah!
http://patches.libav.org/patch/29771/Romansh wrote:Justin (Ruggles) has a patch for 24-bit FLAC which looks a tad cleaner that the MakeMKV one. It's mostly ready and just needs cleanup, but it's not terribly high on his priority list.holunder2 wrote:@mike admin:
@Romansh: Wow, great! Thank you very much for you work! ?
I'm not Justin thoughholunder2 wrote:@Romansh: Wow, great! Thank you very much for you work! ?
