Request subtitle help.
dlyahoo
Post by dlyahoo » Fri Jun 22, 2012 11:03 am
I am having some difficulty transferring subtitles with my process. I have used makemkv to backup DVDs, then converted the file to MP4 using handbrake. The subtitles are always selectable/available and the quality is great. When I try the same process with blu rays however, it's not so easy. I've tried selecting only the main subtitle, the forced subtitle, both, all available subtitles on the blu ray disc, and have yet to be able to select a subtitle to add in handbrake. Any suggestions?? Thanks.
Chetwood
Re: Request subtitle help.
Post by Chetwood » Sat Jun 23, 2012 4:51 am
Have you searched this forum for "handbrake"?
dlyahoo
Post by dlyahoo » Sat Jun 23, 2012 5:35 pm
I have perused a number of posts about subtitles and handbrake. It looks like the blu ray subs are contained in a PGS format and to transfer them a second program is required to convert subs to VOBs, then add the VOBs to the video in handbrake during the conversion to MP4. I was hoping for a simpler (no additional bluray conversion req'd) solution. Like maybe I was just not seeing the correct option to check. Thanks.
Post by Woodstock » Sat Jun 23, 2012 11:31 pm
What version of Handbrake are you using, the release version, or one of the nightly builds?
The nightly builds support burning PGS subtitles into MP4 files, but the release version does not.
dlyahoo
Post by dlyahoo » Sun Jun 24, 2012 9:12 pm
HandBrake 0.9.6 standard, no nightly build additions. I'll give that a shot, thanks.
dlyahoo
Post by dlyahoo » Sun Jun 24, 2012 9:42 pm
BOOM! Problem solved, thanks again!
