I've had MakeMKV setup backing up my Blu-Ray collection flawlessly, but I've recently begun working on my DVD's. Started with Billy Madison, Liar Liar, and Little Nicky.
I've backed up 200+ movies (both blu-ray and DVD) successfully, but these movies refuse to backup correctly. They ALWAYS have video and audio de-sync. The video appears to be moving too fast (like 1.25x speed) and seems to have the quality of a crappy oldschool VHS tape (blurred artifacts and all).
Any suggestions on what I'm doing wrong with these movies? Appears to be Universal DVD's giving me the problems..
Issues with multiple regular DVD's.
Izusaga
Re: Issues with multiple regular DVD's.
Zero suggestions on this? I've had a dozen DVD's with this issue. =/
Smithcraft
I would suggest that you enable debugging and post a log.
SC
SC
Izusaga
Just tried this. There is no debug log created (even when the debug log check box is enabled and the program is restarted and verified the setting persisted).
I am assuming the log does not get created if there are no errors?
crowfax
you would be incorrect in assuming that.
the debug log will always be created.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
Izusaga
Attached is problem child ground zero - Billy Madison DVD.
Debug log started at Thu Jun 21 18:57:17 2012 , written by MakeMKV v1.7.5 win(x64-release)
001005:0000 MakeMKV v1.7.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\s01/MakeMKV_log.txt
003028:0000 Title #0 was added (16 cell(s), 1:27:32)
003025:0000 Title #1 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 18-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (17 cell(s), 1:29:42)
003025:0000 Title #0/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=1 pgcn=1 hash=BAB420318311835A
003025:0000 Title #1 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (1 cell(s), 0:03:43)
003025:0000 Title #2/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=2 hash=325758F1472DC5C0
003028:0000 Title #3 was added (1 cell(s), 0:05:38)
003025:0000 Title #3/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=85D4B85329B430AA
003028:0000 Title #4 was added (1 cell(s), 0:08:57)
003025:0000 Title #4/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=2 hash=5E4882B8A3E63766
003028:0000 Title #5 was added (1 cell(s), 0:05:51)
003025:0000 Title #5/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=3 hash=42830C4EE6753FA4
003028:0000 Title #6 was added (1 cell(s), 0:05:46)
003025:0000 Title #6/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=4 hash=1EA739DEA905E05F
003028:0000 Title #7 was added (1 cell(s), 0:04:40)
003025:0000 Title #7/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=5 hash=005E46CEAE750428
003028:0000 Title #8 was added (1 cell(s), 0:02:00)
003025:0000 Title #8/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=6 hash=EDBD9D67870548E7
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #9 was added (6 cell(s), 0:32:52)
003025:0000 Title #9/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=7 hash=42937BB27CB47706
003025:0000 Title #10 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory E:/Rips/Test
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Thu Jun 21 19:01:09 2012
crowfax
This is likely a problem with your playback software. There is nothing in your debug log to indicate an issue with A/V sync.
Izusaga
Using a default install of PS3 Media server. It works 100% for Blu-Ray rips, but does not process SOME DVD's incorrectly. I just installed PS3 Media Server on a fresh VM and still have the same issues.. will investigate further.
Thanks.
Thanks.
setarip_old
@Izusaga
Hi!
Try playing them on both a standalone DVD player and your PC...
Hi!
