Issues with multiple regular DVD's.
Izusaga
Post by Izusaga »
I've had MakeMKV setup backing up my Blu-Ray collection flawlessly, but I've recently begun working on my DVD's. Started with Billy Madison, Liar Liar, and Little Nicky.
I've backed up 200+ movies (both blu-ray and DVD) successfully, but these movies refuse to backup correctly. They ALWAYS have video and audio de-sync. The video appears to be moving too fast (like 1.25x speed) and seems to have the quality of a crappy oldschool VHS tape (blurred artifacts and all).
Any suggestions on what I'm doing wrong with these movies? Appears to be Universal DVD's giving me the problems..
Izusaga
Re: Issues with multiple regular DVD's.
Post by Izusaga »
Zero suggestions on this? I've had a dozen DVD's with this issue. =/
Smithcraft
Post by Smithcraft »
I would suggest that you enable debugging and post a log.
SC
Izusaga
Post by Izusaga »
Just tried this. There is no debug log created (even when the debug log check box is enabled and the program is restarted and verified the setting persisted).
I am assuming the log does not get created if there are no errors?
crowfax
Post by crowfax »
you would be incorrect in assuming that.
the debug log will always be created.
Izusaga
Post by Izusaga »
Attached is problem child ground zero - Billy Madison DVD.
Debug log started at Thu Jun 21 18:57:17 2012 , written by MakeMKV v1.7.5 win(x64-release)
001005:0000 MakeMKV v1.7.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\s01/MakeMKV_log.txt
003028:0000 Title #0 was added (16 cell(s), 1:27:32)
003025:0000 Title #1 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 18-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (17 cell(s), 1:29:42)
003025:0000 Title #0/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=1 pgcn=1 hash=BAB420318311835A
003025:0000 Title #1 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (1 cell(s), 0:03:43)
003025:0000 Title #2/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=2 hash=325758F1472DC5C0
003028:0000 Title #3 was added (1 cell(s), 0:05:38)
003025:0000 Title #3/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=85D4B85329B430AA
003028:0000 Title #4 was added (1 cell(s), 0:08:57)
003025:0000 Title #4/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=2 hash=5E4882B8A3E63766
003028:0000 Title #5 was added (1 cell(s), 0:05:51)
003025:0000 Title #5/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=3 hash=42830C4EE6753FA4
003028:0000 Title #6 was added (1 cell(s), 0:05:46)
003025:0000 Title #6/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=4 hash=1EA739DEA905E05F
003028:0000 Title #7 was added (1 cell(s), 0:04:40)
003025:0000 Title #7/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=5 hash=005E46CEAE750428
003028:0000 Title #8 was added (1 cell(s), 0:02:00)
003025:0000 Title #8/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=6 hash=EDBD9D67870548E7
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #9 was added (6 cell(s), 0:32:52)
003025:0000 Title #9/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=7 hash=42937BB27CB47706
003025:0000 Title #10 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory E:/Rips/Test
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Thu Jun 21 19:01:09 2012
crowfax
Post by crowfax »
This is likely a problem with your playback software. There is nothing in your debug log to indicate an issue with A/V sync.
Izusaga
Post by Izusaga »
Using a default install of PS3 Media server. It works 100% for Blu-Ray rips, but does not process SOME DVD's incorrectly. I just installed PS3 Media Server on a fresh VM and still have the same issues.. will investigate further.
Thanks.
setarip_old
Post by setarip_old »
@Izusaga
Hi!
Try playing them on both a standalone DVD player and your PC...
