iCarly Season 3 Disc 1 provides fake title messages. There are 6 episodes of about 23.5 minutes each, and it shows 7 titles of that length and has fake title messages next to each. Any assistance on how I can get it to work for this DVD would be much appreciated.
MakeMKV v1.7.4 win(x64-release) started
Title #1 declared length is 2:21:40 while its real length is 0:50:34 - assuming fake title
Title #3 declared length is 2:21:40 while its real length is 0:50:34 - assuming fake title
Title #7 declared length is 2:21:40 while its real length is 0:50:34 - assuming fake title
Title #28 declared length is 0:23:37 while its real length is 0:11:47 - assuming fake title
Title #40 declared length is 0:23:36 while its real length is 0:11:47 - assuming fake title
Title #42 declared length is 0:23:36 while its real length is 0:11:47 - assuming fake title
Title #47 declared length is 0:23:37 while its real length is 0:11:52 - assuming fake title
Title #56 declared length is 0:23:37 while its real length is 0:11:48 - assuming fake title
Title #57 declared length is 0:23:37 while its real length is 0:11:48 - assuming fake title
Title #65 declared length is 0:23:37 while its real length is 0:11:48 - assuming fake title
Title #71 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #75 was added (2 cell(s), 0:02:12)
Title #97 was added (1 cell(s), 0:05:00)
Title #98 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #98/1 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
iCarly - Season 3 Disc 1, fake title
- MakeMKV_log.txt
- (2.58 KiB) Downloaded 638 times
Re: iCarly - Season 3 Disc 1, fake title
There is no change after updating to 1.7.5.
I can't help you but I can confirm I see basically the same thing on linux x64 1.7.7, iCarly season 4 disc 1. I believe this might be a bug as reported elswhere in the forum.
