anybody having trouble with Contagion?
I am getting a failed on it
Contagagion
Re: Contagagion
turn on debugging
post log file
post log file
flanntastic
Re: Contagagion
MakeMKV v1.7.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\HTPC/MakeMKV_log.txt
DEBUG: Code 100864144 at qvQ*ZyYt$#%*UlBjV+:213132100
DEBUG: Code 100864144 at qvQ*ZyYt$#%*UlBjV+:29393930
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '534528'
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00900.m2ts' at offset '325632'
Loaded 48 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from 00000024.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00100.mpls was added as title #0
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00013.m2ts has length of 130 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00002.m2ts has length of 109 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00012.m2ts has length of 34 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00011.m2ts has length of 144 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00010.m2ts has length of 143 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/Contagion
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '15342563328'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '15342587904'
DEBUG: Code 0 at UXyWBGiutclp'!9.lGu7:213130950
DEBUG: Code 0 at ]"B0%|n^BLbZlaa[?Gl :121261681
DEBUG: Code 0 at UXyWBGiutclp'!9.lGu7:29394045
DEBUG: Code 7491498 at UXyWBGiutclp'!9.lGu7:29393332
DEBUG: Code 0 at SPT>#N;twF^Jnfq+hJ#q2:29397955
Failed to save title 0 to file C:/Video/Contagion/Contagion_t00.mkv
0 titles saved, 1 failed
Re: Contagagion
This is not a MakeMKV issue.
There is no copy protection that can stop you reading a disc.
Your disc is damaged or dirty, try cleaning it and try ripping again.
If that fails return it for a new one.
flanntastic
Re: Contagagion
I will try that!
thanks!
thanks!
