Chronicle
Smithcraft
Re: Chronicle
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
However I don't see Chronicle listed, so you might need to rip both and see which one is correct.
SC
SC
Re: Chronicle
You can try playing on an actual Blu-ray player and see if you can get a playlist number from one of the information displays when it's playing. Then you can match that up with the info in MakeMKV. It sounds like there might be a version with an alternate ending, deleted scenes put back in, or something like which you'd be able to that available from the menus.
BlackDragon24
Re: Chronicle
The larger one is the director's cut.
