Chronicle
efithian
Chronicle
Post by efithian » Thu Jun 14, 2012 4:11 pm
Rips ok to mkv, but there are two files of 19GB and 18GB. Which one is the correct one?
Smithcraft
Re: Chronicle
Post by Smithcraft » Thu Jun 14, 2012 9:35 pm
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
However I don't see Chronicle listed, so you might need to rip both and see which one is correct.
SC
paulster
Re: Chronicle
Post by paulster » Thu Jun 14, 2012 11:28 pm
You can try playing on an actual Blu-ray player and see if you can get a playlist number from one of the information displays when it's playing. Then you can match that up with the info in MakeMKV. It sounds like there might be a version with an alternate ending, deleted scenes put back in, or something like which you'd be able to that available from the menus.
BlackDragon24
Re: Chronicle
Post by BlackDragon24 » Sat Jun 16, 2012 2:32 pm
The larger one is the director's cut.
