List of DVD/BluRay that haven't worked
Zippolighter
Re: List of DVD/BluRay that haven't worked
Post by Zippolighter »
Transporter 3 german BD don't work
Attached MakeMKV Log
MakeMKV_log.txt
Zippolighter
21 german BD don't work
MakeMKV send the message in the GUI no response
MakeMKV_log.txt
Post by mike admin »
Zippolighter wrote:Transporter 3 german BD don't work
MakeMKV_log.txt
This one and next one logs show that you are opening blu-ray files on hard drive. The files do not have AACS directory present but M2TS files appear to be encrypted, so the program fails.
Zippolighter
Hello mike admin,
thanks for the fast answer.
The behavior was the same as I try to create the mkv direct from the BD.
For my point of view the files are not encrypted. It is possible to play the m2ts files with vlc.
So the question is, why MakeMKV shows the files as encrypted. Many other BDs works fine with MakeMKV from BD and HD.
Andie
Post by Andie »
mike admin wrote:
Andie wrote:
Andie wrote:Friday "New Line Platinum Series" DVD. It reads a few tracks none of which are the movie.
Tried it with the new version (1.4.9) and still no good. Reads a few tracks all less than 3 mins. Here's the log:
003025:000000:0000 Drive BD-ROM ATAPI iHOS104 WL0B has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Is it title 3? And my BD-ROM keeps giving me that error even though I set it up for region 1. What does that mean exactly? Ditto with Geisha. The only 2 DVDs in my collection that won't rip! :lol:
Well, it is what it says - it looks like these 2 discs are not region1 discs and you have a drive that _really_ enforces the region code. my only advice is to try to read them with another drive.
Thanks for the feedback Mike. Unfortunately, I've already tried on 2 (this one makes 3) drives and it's the same thing. Only reads a few tracks all a few minutes long. And Geisha just crashes the program. No worries though.
microjazz
Post by microjazz »
Hello, I posted the problem with the blu ray star trek disks. Sorry it has taken me so long to get back with the logs.
This is what MakeMKV shows before I start it. When it's done it shows 3 titles that I can rip of Season 1 Disc 3 of Star Trek. The problem is there are four episodes on this disc. The three episodes available rip fine but I am unable to select this 4th episode. Seeing as how MakeMKV doesn't even see the file I figured I'd post this rather than a post rip log. Let me know if you need more info.
MakeMKV v1.4.9 beta win(x64-release) started
AACS directory not present, assuming unencrypted disc
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00000.m2ts
Stream #10 of type 'DTS-HD secondary audio' in file 00000.m2ts was skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00063.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00064.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00066.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00067.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00070.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00071.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00073.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00074.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00076.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00077.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00079.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00080.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00082.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00083.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00085.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00086.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00088.m2ts
File 00000.mpls (angle 1) was added as title #0
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00001.m2ts
Stream #10 of type 'DTS-HD secondary audio' in file 00001.m2ts was skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00065.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00068.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00072.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00075.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00078.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00081.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00084.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00087.m2ts
File 00000.mpls (angle 2) was added as title #1
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00069.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00089.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00091.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00092.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00094.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00095.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00097.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00119.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00099.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00100.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00101.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00102.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00121.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00104.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00106.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00107.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00109.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00110.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00111.m2ts
File 00002.mpls (angle 1) was added as title #2
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00090.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00093.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00096.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00098.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00120.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00103.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00105.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00108.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00122.m2ts
File 00002.mpls (angle 2) was added as title #3
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00117.m2ts
Stream #10 of type 'DTS-HD secondary audio' in file 00117.m2ts was skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00032.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00033.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00035.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00045.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00047.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00048.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00050.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00051.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00053.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00054.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00056.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00057.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00059.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00060.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00062.m2ts
File 00003.mpls (angle 1) was added as title #4
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00118.m2ts
Stream #10 of type 'DTS-HD secondary audio' in file 00118.m2ts was skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00034.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00046.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00049.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00052.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00055.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00058.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00061.m2ts
File 00003.mpls (angle 2) was added as title #5
File 00009.mpls was added as title #6
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00036.m2ts
File 00036.m2ts was added as title #7
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00037.m2ts
File 00037.m2ts was added as title #8
Title #00160.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00161.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00164.m2ts was added as title #9
Title #00169.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00186.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00203.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00038.m2ts
File 00038.m2ts was added as title #10
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00039.m2ts
File 00039.m2ts was added as title #11
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00040.m2ts
File 00040.m2ts was added as title #12
Title #00009.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00042.m2ts
File 00042.m2ts was added as title #13
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00043.m2ts
File 00043.m2ts was added as title #14
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00010.m2ts
File 00010.m2ts was added as title #15
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00044.m2ts
File 00044.m2ts was added as title #16
Title #00011.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00013.m2ts
File 00013.m2ts was added as title #17
Title #00014.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00016.m2ts
File 00016.m2ts was added as title #18
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00028.m2ts
File 00028.m2ts was added as title #19
Title #00029.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Zippolighter
Problem with I Am Legend BD.
MakeMKV start to Opening Blue-ray disc, then it looks like makemkv is frozen
Debug log started at Fri Dec 11 15:11:37 2009 , written by MakeMKV v1.4.9 beta win(x64-release)
001014:000000:0000 MakeMKV v1.4.9 beta win(x64-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Andreas/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003316:000000:0000 Only extracting AC3 core audio from stream #2 of type 'DD True HD audio' in file 00000.m2ts
001012:000000:0020 FAILURE: Code 0 at u=hU4hJQ*e{M_P%h,]":29398484
001012:000000:0020 FAILURE: Code 0 at B?]l@f48taE[hyX rTA5:29394896
001012:000000:0020 FAILURE: Code 4294967219 at s5k'Ka4jU!deW6/L:29398760
001012:000000:0020 FAILURE: Code 4294967219 at kl|kZ#^s6U7<Ho6rGH:213130145
001012:000000:0020 FAILURE: Code 4294967219 at kl|kZ#^s6U7<Ho6rGH:213130697
001012:000000:0020 FAILURE: Code 4294967219 at kl|kZ#^s6U7<Ho6rGH:213132146
002007:000000:0000 Read error. File="<n/a>" Info=""
001012:000000:0020 FAILURE: Code 0 at UH7f:T<|aJI1;<ixA_XN:213132376
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:29393516
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:213129639
001012:000000:0020 FAILURE: Code 0 at 44?G=bdrG^_VQ86[Dc%*j:121264326
001003:000000:0020 DBG ASSERT: }%79@FGD`UF,U9IlP}]2GKwGN )C1"op& at o$^4itipyd@VU3'R|%:@<< ^r:121262026
001012:000000:0020 FAILURE: Code 0 at s5k'Ka4jU!deW6/L:29397104
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:121262509
001012:000000:0020 FAILURE: Code 0 at UH7f:T<|aJI1;<ixA_XN:213130053
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:121262164
leylandleopard
Post by leylandleopard »
Forgetting Sarah Marshall - BD
MakeMKV 1.4.9
Failed to save title. Failure Codes below.......
Saving 2 titles into directory D:/Video/Forgetting_Sarah_Marshall
FAILURE: Code 4294967276 at d_QUY|<nv#xUl1cO:213135665
FAILURE: Code 0 at d_QUY|<nv#xUl1cO:29398691
FAILURE: Code 4294967276 at i_0P)({$&hcD0}jFs!:29394045
FAILURE: Code 4294967276 at i_0P)({$&hcD0}jFs!:213130697
FAILURE: Code 4294967276 at i_0P)({$&hcD0}jFs!:213132146
FAILURE: Code 0 at jO;U-c4et;`hTV*`TTo":121262509
FAILURE: Code 0 at [:-#Q'n$Wl)M1)e*BhTf:213130053
FAILURE: Code 0 at jO;U-c4et;`hTV*`TTo":121262164
FAILURE: Code 30 at jO;U-c4et;`hTV*`TTo":213129639
FAILURE: Code 0 at ~1!kE{v:q(a_#_<9eP4`O:121264326
FAILURE: Code 0 at pA":BS.jxS`m=6PVu9::121261980
FAILURE: Code 0 at pA":BS.jxS`m=6PVu9::213131502
Failed to save title 2 to file D:/Video/Forgetting_Sarah_Marshall/title02.mkv
FAILURE: Code 96 at jO;U-c4et;`hTV*`TTo":213129639
Failed to save title 3 to file D:/Video/Forgetting_Sarah_Marshall/title03.mkv
0 titles saved, 2 failed
garywilson
Post by garywilson »
hello everyone
i am gary , new to forum. thanks for share list of not working app.
Laparoscopic Adjustable Banding | adirondack chairs for | premium sms Australia
Zippolighter wrote:Problem with I Am Legend BD.
What software did you use to decrypt this disc? It appears that the disc is decrypted but flags in M2TS files indicate that files are encrypted. MakeMKV can't find a decryption key and dies.
leylandleopard wrote:Forgetting Sarah Marshall - BD
Apparently regular read error, scratched disc or similar.
Zippolighter
I use AnyDVD HD to encrypt.
But on I am Legend I try it directly from the BD with makemkv. It looks like that expect the AACS directory but on this BD it is not available or on an different location.
Just to confirm you are trying to open a disc with AnyDVD HD running in background? We'll investigate.
The easy solution is to disable AnyDVD - MakemKV does not need it and disc should open properly.
Zippolighter
mike admin wrote:Problem with I Am Legend BD.
I test it again to create mkv from I am Legend BD. AnyDVD was finished before MakeMKV was started.
So the error is different, makemkv isn't frozen, but don't create the mkv
Debug log started at Mon Dec 14 09:52:42 2009 , written by MakeMKV v1.4.9 beta win(x64-release)
001012:000000:0020 FAILURE: Code 0 at ooCJUm;D;N?a'[ve<:121262164
001012:000000:0020 FAILURE: Code 0 at u=hU4hJQ*e{M_P%h,]":213133043
DISCID=356D802C2354DAD7259D1AA1FFFA1EE21DA3B6A5
001012:000000:0020 FAILURE: Code 0 at B?]l@f48taE[hyX rTA5:121263590
001012:000000:0020 FAILURE: Code 4294967251 at s5k'Ka4jU!deW6/L:213135665
003313:000000:0000 File 00000.mpls was added as title #0
001012:000000:0020 FAILURE: Code 0 at 7;|)s?^>aOqSyFu/ji@m:121265614
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory D:/Bearbeiten/MakeMKV/I Am Legend
tp=ZeNq7H8oTvzpx4o7cvu36uYzHN/S9g4L3cjYVHx/nbvv5Oera1rXZUKKBgYG55nYO77bbuXuA0rt37+ADqmUvZ0BRDVN+gYGBIaHmdkIuUPnj4/2yd+8+AJv9AKT42G2d+Tyaj7a6VT578mh1QnZjZHdK0ebdDgsPJ/7R+1V+SrXn9DXGD2q6cqcZru+qzDlf8M3mgNftHKbKTv/6N1PmbJ7yFADxUm1n
001012:000000:0020 FAILURE: Code 0 at UH7f:T<|aJI1;<ixA_XN:213130651
tp=ZeNpbXZBucz+UJ3514sQduX3b9XMZj2/oewcF7+VsKj4+zt3283PUta1rs6FEAwMDc83tHN5tt3P3AKV3797BB1TLXs6Aohqm/AIDA0NCze2EXKDyx8f7Ze/efQA2+wFI8bHbOvN5NB9tdat89uTR6oTsxsjulKLNux0WHk78o/er/JRqz+lrjB/UdOVOM1zfVZlzvuCbzQGv2zlMlZ3+9W+mzNk85SkAPgJvJQ==
ts0=ZeNqtVX00k3scf8ak6UVcuSJTaDV0G12TrFm50Yu45S43dSOtWjFWbrbV8pLmLUw1OhTKW7Kwzu6WUmyllhZK7uaYsRotJ00sDr3eZ7Pi9kf3/tH3nOf54/l9ft/z+XxfPk+boHaBn6uhNUUbTDiGOsSX0cerIkIkPP0LB+AgiRqqjMSXkW6uVop0SApE3gWA6OFZfJmqmRRhM4EfAp9HAACE0WWR4ElsN4YjptF4Vr1ml+NnIlX3RSbRKblclBizM8l393HhhnsnqvZY3jbbpp73pDTaEx8+6nKYcz2o7AG1v/kBT/Iwp7tlVkrGnqYaRmvlVpF4JNZZ4JipWReiQZYb1ZoMP9ibDGWT92F68DND2btO1ZKyri0jQUScLLU+BrV6lCT+uGZSTogkAQAMJ/iRboLHdXW1s0GsMQX4F/ozXC8nTCtfKWLayuUKXW6FFnxP5lI0E/mM50t73vuMHRaRuO0k4RC3Dnfxzq73P72lPFiUIZZAXiOWwsWA9AYtspU8ihFskEUa0NIC4wdY57msPq5vZB2sOpxtEjDrBc9nn+9bssWSzsWwchf7nPVridzk4GkhFWaNiU6FwcON3+oRAKkn8efyZUSQJKhf4VWnjUZgSCnKnIK+N6UCWkX8oc8N1adGFywJKvUuwBTu3m/PLFRBIzcQ8DROayHkCeSDhj6DmW2GS7CnwSLLiDuWhGdch07r9Gm0RRGsZttWr/LfocpMwyFwbOJB18IKocPt1IC+qru7TOpsCOtMPVEak5hVDdvnHcmPyT9hSxhO6aAFOktP2u0fIWPAqoK1hWNI/B4syE/C45VYy3SULwDA9G6slioHPTRFWi1A1UnroOuKIG3W6SOCzULRP8Lt7twZo4YCHbgMAGAApmXPL3HZXbkh6u2fHEZyUm9RUA4DWb5NBx2tVn8wFcHfvCwxogUtrvA7bb4Suld2z7wQ5W50YaGNmMnePxe9GfpeyqUsO1fW3TnLvg8br/RMjPiYTu3nDjJir44WsxjvzjOuhrkElodXz/0YcWb273WKBpQwq+b0j8CUoFAMteUGl0W3JaFY+mARRKlqtcPSxzUqATAdMBQqRalabQnA16H/Ah5+ySHh1RR5qVqL/F8dMD+LIOCScR3tMf2pG0YcPsSLPM7CXmavtX447cr0zCbmsp3FBN9VQOhrDdXNnH0+Lv2F94znUUcSuMS+pr2e2MaMg17R/Tf7K5ot/So9UQZYGIdHD7uLjxMY/1KcJjE/ayJNHEI9JZYMwNTy94NdAXe/J/82IdDu52pgMznMIBDCoU/cMKSPoH0eUTubVKSVzNSV+RKjbYsFucwVtW4+MoTBnAVLq1YXl/LWX30ddOXiijm5ZXvsnJa/dHsj7BDNXyPYsuKt0xqawsWj1NEfUb7xt12O7SN5iXfT71uaHpew2DuILUee+pCtBiX40hfWM4LG7OVfQrc0EzQn1wwcRcCjWacgGo7R70yb0JgM+qeN3kr0oZ1l0DHr6V/f78kLRrT1vJ8zxELlIW85nPN1ZMCC/yYB0y44U6nPk9U/4CjJlq7tUSk3rNelMyxO2nPfnVGzYr0Tguov/1ESLr24aO+WmVJoTwNx/eMzAXEbu2El2ccKCA4Nje7+DfmbMnJ2yG3ri2NH00qScvNict1VR7L9DeBoWZTeAne6T1JBa5W0CS0q/FyhNvxu0Fam6J9cRt5UJ4w+p3MNEPzZY9VDWjBaFl2kS12PXH4ZOXvhZbjbMi+kT19AeS879OMYnNstYkkJls2lW/CdYwRM16X942nklN7ysDj8UsGWpI7eJqt32/0U/GsbR4WEa6wFK/N20g6YOqtHRkMYQk8DY/IpabyFyCEpPDNcIKwOPPpwXvpyYy2PNuFChZ+rkQ3pewnQo4n6Zteo1p5Pa8Hmy5FyuvGwuMyuALL4z/GNxzLZqMMWj9OoRIQS75wNRZ9ZQ3Hynv9Xr9Ehj6gBcUtcS/DDrNtOle6VR023+ge+9YF/UshzfsW/2HTlVU2Ep4v/M5lBys9oDr9rcwGeeTK6S4HAcs0KztG7j3mb/4fLa9v2/4YNPfHT/hb4H1ptGO4=
001012:000000:0020 FAILURE: Code 123 at %q1g5G[RBgR%&*YOO.U4:213129639
001012:000000:0020 FAILURE: Code 0 at 44?G=bdrG^_VQ86[Dc%*j:121264211
001012:000000:0020 FAILURE: Code 0 at b<LG[(0CM{E{qVnyz2]:121263268
001012:000000:0020 FAILURE: Code 0 at b<LG[(0CM{E{qVnyz2]:213134998
001012:000000:0020 FAILURE: Code 0 at b<LG[(0CM{E{qVnyz2]:213132537
001012:000000:0020 FAILURE: Code 0 at b<LG[(0CM{E{qVnyz2]:121261888
FS ID=V_MS/VFW/FOURCC C=21
C_00000=ZeNp7PC/o/YUwBob/UMDIAAH/0QATUIyJAROIq8BYjPy3/1l/ku6y/tH2scGLiYmZc706uzoLUIIv6v6f9ydyHIBM3gNODAzMCNTM/Keixk6ev/3www8/RhmjjFHGKGOUMcoYZYwyRhmjjFHGKGOUMcoYZQxuBgCT6uU8
C_00001=ZeNqbePX4twthDAz/oYABCv6jAWagGBMDJmCFsxh5PwEAIYYdPA==
C_00002=ZeNprfnnu44UwBob/UMAABf/RAAtQjIkBCUhAqCxWmAAjb6MCZ/1/TKD/fwDBowMbdLiZSCHksZjyhYGBGY4Y/wQgc0fRKBpFo4hOqAEAY1rYaw==
C_00003=ZeNrrivf+ciGMgeE/FDBAwX80wAIUY2LABFmsMBYjb5cCZ/1/TKD/fwDBowMbdLiZSCHksZjyhYGBGY4Y/wQgc0fRKBpFo4hOqAEATq/XWQ==
C_00004=ZeNpz4LH9dyGMgeE/FDBAwX80wAwUY2LABKxwFiPvJwCnUBug
C_00005=ZeNqb4e3y80IYA8N/KGCAgv9ogAUoxsSACbJYYSxG3k4Fzvr/mED//wCCRwc26HAzkULIYzHlCwMDMxwx/glA5o6iUTSKRhGdUAMAG8zXUA==
C_00006=ZeNqzmHbg94UwBob/UMAABf/RAAtQjIkBE2SxwliMvE0KnPX/MYH+/wEEjw5s0OFmIoWQx2LKFwYGZjhi/BOAzB1Fo2gUjSI6oQYAStnXsg==
C_00007=ZeNp757SJ9WIYA8N/KGCAgv9ogBkoxsSACVjhLEbeTwDGRBwB
C_00008=ZeNpzb9rJcDGMgeE/FDBAwX80wAIUY2LABFmsMBYjb6MCZ/1/TKD/fwDBowMbdLiZSCHksZjyhYGBGY4Y/wQgc0fRKBpFo4hOqAEAc/zWqw==
C_00009=ZeNrz+2HKfDGMgeE/FDBAwX80wAIUY2LABFmsMBYjb5cCZ/1/TKD/fwDBowMbdLiZSCHksZjyhYGBGY4Y/wQgc0fRKBpFo4hOqAEAjlPWsA==
C_00010=ZeNpjXqrOezGMgeE/FDBAwX80wAwUY2LABKxwFiPvJwB2kBr2
C_00011=ZeNr7ukOP42IYA8N/KGCAgv9ogAUoxsSACbJYYSxG3k4Fzvr/mED//wCCRwc26HAzkULIYzHlCwMDMxwx/glA5o6iUTSKRhGdUAMAyITXFA==
C_00012=ZeNr7o7ea62IYA8N/KGCAgv9ogAUoxsSACbJYYSxG3iYFzvr/mED//wCCRwc26HAzkULIYzHlCwMDMxwx/glA5o6iUTSKRhGdUAMAi3zXCQ==
C_00013=ZeNpb/H4x/8UwBob/UMAABf/RADNQjIkBE7DCWYy8nwDhkBxe
C_00014=ZeNrbESgpfjGMgeE/FDAyQMB/NMAEFGNiwATcBjAWI//tf9afpLusf7R9bPBiYmLmXK/Ors4ClOCTuv/n/YkcByCT94ATAwMzHDFe4OH/+FBOcBSNolE0ikbRKBpFo2gUjaJRNIpG0SgaRUMBAQDLRcCK
C_00015=ZeNpblaogdDGMgeE/FDBAwX80wAIUY2LABFmsMBYjb6cCZ/1/TKD/fwDBowMbdLiZSCHksZjyhYGBGY4Y/wQgc0fRKBpFo4hOqAEALgTWcg==
C_00016=ZeNrbeHuOyMUwBob/UMAABf/RAAtQjIkBE2SxwliMvE0KnPX/MYH+/wEEjw5s0OFmIoWQx2LKFwYGZjhi/BOAzB1Fo2gUjSI6oQYAnJfXZg==
C_00017=ZeNpL7+iTuxjGwPAfChig4D8aYAaKMTFgAlY4i5H3EwCvHxu1
C_00018=ZeNqLmDNV8mIYA8N/KGCAgv9ogAUoxsSACbJYYSxG3kYFzvr/mED//wCCRwc26HAzkULIYzHlCwMDMxwx/glA5o6iUTSKRhGdUAMAKi7Wyw==
C_00019=ZeNpLEBKSuRjGwPAfChig4D8aYAGKMTFggixWGIuRt0uBs/4/JtD/P4Dg0YENOtxMpBDyWEz5wsDADEeMfwKQuaNoFI2iUUQn1AAAno3V0g==
C_00020=ZeNoT3c+sdjGMgeE/FDBAwX80wAwUY2LABKxwFiPvJwCAYBsX
001012:000000:0020 FAILURE: Code 0 at b<LG[(0CM{E{qVnyz2]:29393838
001012:000000:0020 FAILURE: Code 0 at G>4qk)o,"*Ru*\8-i0=:121261980
001012:000000:0020 FAILURE: Code 0 at G>4qk)o,"*Ru*\8-i0=:213131502
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file D:/Bearbeiten/MakeMKV/I Am Legend/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Zippolighter
I try it again to create the mkv from I Am Legend and now its worked.
I don't know what is the different to the last 5 or 6 trys to create makemkv if is not work.
So you must no longer investigate time to finde the problem with the I AM Legend BD. I think the always available problem is the interaction with AnyDVD HD
Cheers Zippolighter
