Drive fails on UHD on Linux
kenwilliams5
Post by kenwilliams5 » Wed Nov 25, 2026 5:51 am
I don't know exactly where to start, but I have a USB drive that worked fine under Windows and I have ripped many UHD movies.
I decided to move away from Windows and loaded Linux Mint. I loaded MakeMKV v2.0.0 linux(x64-release) and it works fine for Bluray, but errors out on UHD disks.
I get a lot of:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
errors, and at the end, it says:
Downloading latest HK to /home/ken/.MakeMKV ...
and just sits there.
I wouldn't think it's the firmware on the drive, since it work flawlessly on Windows.
Anyone have any ideas?
Thanks in advance
tomty89
Re: Drive fails on UHD on Linux
Post by tomty89 » Wed Nov 25, 2026 3:48 pm
just sits there
"Downloading latest HK" could be really slow, especially for the first sync. You can e.g. `watch du` the private data tar file in ~/.MakeMKV to see if its size is actually growing to find out whether it is really "sitting there" or not (and how fast/slow the download is).
Using a VPN (with a Russia server/node) might help.
The errors might not actually matter. It could be just "red herring", although they shouldn't show up if you are using a LibreDrive (and that the support isn't "blocked" by a lame USB bridge). Also better switch to 1.18.4 since 2.0.0 is somewhat broken anyway.
