Unable to rip The Dead
Larry_Stewart
#1 Post by Larry_Stewart » Sat Jun 09, 2012 1:55 pm
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM00001.mts2' at offset 1628762112
got that read error 4 times then failed at 1628897280 several times.
Reported as failed - no copy
crowfax
Re: Unable to rip The Dead
#2 Post by crowfax » Sat Jun 09, 2012 3:59 pm
This is an error message from your drive. It's telling you it can't read the disc.
This is not a MakeMKV issue, this is a hardware issue.
There are 2 possibilities:
  • Your disc is dirty/damaged/poorly manufactured.
  • Your drive is dying.
Option one is significantly more likely. Try cleaning the disc, if that doesn't work then return it for a new one.
Larry_Stewart
#3 Post by Larry_Stewart » Sat Jun 09, 2012 4:08 pm
crowfax wrote:This is an error message from your drive. It's telling you it can't read the disc.
Thanks crowfax!
